adding new output to project
I have a code that runs perfectly but when I add some test signal and assign the pins it give the following error
ERROR: Drc 23-20] Rule violation (UCIO-1) Unconstrained Logical Port - 1 out of 92 logical ports have no user assigned specific location constraint (LOC). This may cause I/O contention or incompatibility with the board power or connectivity affecting performance, signal integrity or in extreme cases cause damage to the device or the components to which it is connected. To correct this violation, specify all pin locations. This design will fail to generate a bitstream unless all logical ports have a user specified site LOC constraint defined. To allow bitstream creation with unspecified pin locations (not recommended), use this command: set_property SEVERITY {Warning} [get_drc_checks UCIO-1]. NOTE: When using the Vivado Runs infrastructure (e.g. launch_runs Tcl command), add this command to a .tcl file and add that file as a pre-hook for write_bitstream step for the implementation run. Problem ports: test_LA[15]
I have defined constraints for all the pins
Please suggest some solution
uzmeed
Re: adding new output to project
Hi @uzmeed ,
Please check this AR# link, might be helpful:
https://www.xilinx.com/support/answers/56354.html
Raj
Hi, @uzmeed ,
You can check in the implemented design to see whether the port "test_LA[15]" is placed in the expected loc?
If the port "test_LA[15]" is placed in expected loc, you can use the rshekhaw's method to suppress the error message.
If the port "test_LA[15]" is not placed in expected loc, please check when the user's package_pin property are missing. (You can open the opt.dcp, place.dcp and routed.dcp one by one to confirm)
Hi @hongh
I assigned a different pin to the signal and bitsteam generated sucessfully.
I am a bit confused in using the method mentioned by @rshekhaw  as it states that using this option will demage the FPGA, does it really happens that a wrong assignment may cause the FPGA a permanent damage.
Uzmeed
Hi @uzmeed ,
Although Vivado allows you to disable and downgrade the severity of the built-in DRC
Objects, this practice is highly discouraged as it can cause unpredictable results and could potentially
cause permanent damage to the device.
Raj
