clock planning option in ultrascale
I generated open example design for pcie gen3 for xcku035 kintex ultrascale. I wonder while opening implemented design why clock planning option doesn't appear to see transceivers configuration in vivado 16.3. along with i/o planning , floor planning.
Is there any way to open this? may be from TCL command?
Re: clock planning option in ultrascale
Hi @fpgalearner. Thanks for the clarification. That is correct. The Clock Planning Layout will only be seen for 7-Series designs. For UltraScale designs. the report_clock_utilization command is helpful for identifying how many clock resources have been constrained, and gives additional information.
*Please mark replies with the "Accept as solution" option if they are found to be helpful
Hi @fpgalearner. Is there more details, or an image to help identify what is missing in Vivado? Are design objects (cells/ports) related to Transceivers missing. Is a certain Vivado IDE view not present?
It sounds like you might be looking for the IO Planning Layout. This can be selected from the Layout Selector at the top of the IDE. Page 20 of the Vivado IDE Guide has more on this:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_3/ug893-vivado-ide.pdf
Hi @marcb in same 20 page in Vivado IDE you mentioned , there is also clock planning option in dropdown menu. Which does not appear in my case in vivado IDE for ultra scale case design.
@fpgalearner,
If your query is addressed, can you please close this thread by marking the post which answered your query as "Accept as Solution"
--Syed
