snchao
how to fixed [Vivado 12-2285] Cannot set LOC property of instance ?
Dear Sir,
I am using Vivado v2017.1 for MIG IP DDR3.
My device part is  xcvu440-flga2892-1-c.
Here is critical warning log, how to fixed it ?
CRITICAL WARNING: [Vivado 12-2285] Cannot set LOC property of instance 'u_pd_main/u_core_top/u_ddr_top/u_mig/inst/u_ddr3_mem_intfc/u_mig_ddr3_phy/inst/u_ddr_iob/genByte[1].u_ddr_iob_byte/genBuf[0].genblk1.OBUF', Instance u_pd_main/u_core_top/u_ddr_top/u_mig/inst/u_ddr3_mem_intfc/u_mig_ddr3_phy/inst/u_ddr_iob/genByte[1].u_ddr_iob_byte/genBuf[0].genblk1.OBUF can not be placed in OUTBUF of site IOB_X0Y68 because the bel is occupied by u_pd_main/u_core_top/u_ddr_top/u_mig/inst/u_ddr3_mem_intfc/u_mig_ddr3_phy/inst/u_ddr_iob/genByte[5].u_ddr_iob_byte/genBuf[3].genblk1.OBUF(port:c0_ddr3_addr[8]). This could be caused by bel constraint conflict [/projusers/t0337af8/ZIV/UT0337A/UT0337A/0808_ASUS/ASUS_with_NEW_diff_DDR/FPGA/arc_ddr_no_pisp/db_arc_ddr_no_pisp_vivado_run/pad_top_edif.xdc:2616]
Resolution: When using BEL constraints, ensure the BEL constraints are defined before the LOC constraints to avoid conflicts at a given site.
thanks
~SN
vemulad
Hi @snchao
Are you using Vivado GUI or scripts to run synthesis and implementation?
Did you assign the locations to MIG pins on elaborated or synthesized design and run report_drc to ensure pinout is valid?
You will need to rerun implementation from opt_design stage when you change the MIG pinout.
Deepika.
