Visitor dflowerzl
how to invoke synplify_premier in smartxplorer
I'm using smartxplorer of ISE14.2. It by default invokes synplify_pro for synthesis. What can I do if I want it to invoke synplify_premier? Thanks.
Re: how to invoke synplify_premier in smartxplorer
Smartxplorer.exe -p xc6slx16-2-csg324 -uc stopwatch.ucf -sd ".;ipcore_dir" stopwatch.prj
Before running command did you try changing the synthesis strategy to in Design properties of project to synplify_premier?
Vishal
Visitor dflowerzl
Hi Vishal,
I used the command line as in your example. And no, I didn't change any synthesis strategy in project file, just changed relative paths to absolute paths.
The synplify project file doesn't contain any fields to specify which tool to use, synplify_pro or synplify_premier. When I run the command, it automatically invokes synplify_pro. But I want to use synplify_premier instead, and I don't know how to do it.
In ISE, File -> Preferences -> ISE General -> Integrated Tools. Try to change the path of Synplify Pro executive to Synplify Premier executive
Vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
Visitor dflowerzl
Thanks, Vivian
But how can I set it through command line? I use makefile to invoke smartxplorer, and the preferences I set in the GUI seems not taking effect at all.
Community Manager
Community Manager
Please have a look at the following AR. This should set it up for you.
http://www.xilinx.com/support/answers/35475.html
