how to see the partitioned design in the nblock diagram
I created 6 partitions using automatic feature and imolemented it.
But now I am not able to see the implemented partition in the design layout view.
also are there any design examples in xilinx repositary for partitioning and floorplanning ?
Thanks in advance.
check these documents
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_2/ug905-vivado-hierarchical-design.pdf
http://www.xilinx.com/support/documentation/application_notes/xapp918.pdf
http://www.xilinx.com/support/documentation/sw_manuals/xilinx12_2/Floorplanning_Methodology_Guide.pdf
Thanks and Regards
Balkrishan
