importing ooc implemented checkpoint in top level
I have module which is implemented OOC. Now I have a top level module where this OOC implemented module imported as a checkpoint. A number of instances of these OOC modules are generated at the top level. Now even, the top level module is not the exact top level, I mean i want to run OOC synthesis and implementation of this  pseudo top module. Is this possible?
I am reading in the OOC checkpoint and running synth_design with mode out_of_contex and top as top. I dont want IO Buffers to be inserted at the top. I am doing this for a comparison study for the time it takes between normal synthesis and out of context synthesis.
I have dont_touch property set for the reused ooc module. Should dont_touch also be set for the top module?
Next question is, a constraints file is already read in the bottom ooc implementation. The top level reuses the same. I believe there is no need to read the xdc file again.
Also, should a pblock be created and the bottom ooc module be added to this before running top ooc synthesis?
Lastly, should black box attribute be set to the instances being generated in the top module? Here is a sample code:
//Bottom level OOC implemented module
(*dont_touch = "true"*) module qpe_dummy(
clk_dnoc_i,
reset_n_dnoc_i,
clk_ref_i,
reset_n_ref_i,
//Top level in which it is resued/generated:
module qpe_mesh(
clk_dnoc_i,
reset_n_dnoc_i,
clk_ref_i,
reset_n_ref_i,
scan_mode_i
genvar i;
generate
for(i = 0; i < 5; i=i+1)
begin:l_top_mesh
(*black_box*)qpe_dummy i_qpe_dummy(
....ports
end//l_top_mesh
endgenerate
endmodule
Please help with this.
An eager student
Re: importing ooc implemented checkpoint in top level
Hi @prateekj212. Thanks for the clarification. I would definitely weigh the run time options of the OOC vs global flow to see which best suites this design. Typically, the sub-module synthesis run time is much greater than the open_checkpoint, which would make the OOC flow a better option.
The lock_deisgn command is not meant to improve runtime, and might affect run time differently depending on the design. However, one of the main goals of the incremental compile flow is to reduce run time. This flow would reuse as much of the placement and routing information as possible between differing versions of the design.
Hi @prateekj212
I believe you can run the pseudo top module (which is not exact top as per you) as ooc as long as you don't have any Xilinx IP in OOC mode in the lower-levels of the OOC module.  Also if  there are no parameters on the OOC module, or the ports of the OOC module are user-defined types. Refer the link below, page 25:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_4/ug901-vivado-synthesis.pdf
ooc runs xdc are scoped xdc i.e they have there scope only in the module which is set as ooc. Can you verify whether these modules(ooc) xdc file  have SCOPED_TO_CELLS and SCOPED_TO_REF property set on them.
You can also check for the tcl file in <>.runs/synth_1 folder to see if the ooc xdc been read by top run.
Just FYI There is also option to set block level synthesis  to set property, strategy on  particular hierarchy in the project. Refer the above link more info on that.
Rohit
Rohit
There are parameters in the ooc module which is synthesised and implemented. Does that mean the top level in which it is used cannot be run as OOC again?
I am struggling with understanding( Since I am new to Vivado) the difference between synth_design and link_design and the correct context in which to use them.
I have a tcl script flow typically:
read_verilog files..
read_verilog header files..
read_xdc constraints ..
synth_design -mode out_of_context -part some_part -flatten_hierarchy rebuilt -top ooc_module_to_be_resued
#optional opt_design
place_design
#optional phys_opt_design
route_design
write_checkpoint ooc_module
Now in the top level:
read_checkpoint ooc_module.dcp # i believe here open_checkpoint also can be used... So which is better?
#the document says ooc checkpoints dont automatically load a design... in order to facilitate adding more ooc .dcp files in to the design....
add_files top.v
or
read_verilog top.v
link_design -top pseudo_top -mode out_of_context -part somepart
or synth_design -top top.v flatten same.. .same... part
again place
again route
#what should be used in the reuse flow?
Please help.
Eager student
Hi @prateekj212
I would suggest to synthesize the ooc module globally and not as ooc as doing this can cause errors in later part of the flow.
For your top level, open_checkpoint command should be used over read_checkpoint command as open_checkpoint will read the checkpoint, create in memory design and initialize the design in the project.
If you wish to use read_checkpoint then you need to include link_design as well in your script. Refer the link below, page 49:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_4/ug904-vivado-implementation.pdf
Rohit
Rohit
I am not sure what you mean by globally. Do you mean normal synthesis?
If I do normal synthesis, it will insert IO buffers, which I do not want.
regards
an eager student
Hi @prateekj212
Yes
I asked you to do the normal synthesis of your ooc module (naming convention as per you) which has parameters. But you can set the module which reads ooc module checkpoint as ooc.
Rohit
Rohit
I am facing an issue here. I ran out of context synthesis for the top level by normally reading verilog files and then a second time by reading in a design checkpoint file for a presynthesised and routed design.
My question is shouldnt the second scenario be faster than the first one?
I am getting runtime results where second scenario takes double the time taken than the first. Why is this happening?
I need to justify using out of context synthesis.
Please help
Hi @prateekj212. I wanted to clarify on your last post with "I ran out of context synthesis for the top".
The top-level of a design would need IO connectivity from a non-out of context synthesis, so it is not clear why the OOC flow is being used.
The run time benefit of using out of context is having lower-level portions of a design synthesized once, and not synthesizing these when running global (top-level) synthesis. Synthesis sees the OOC portion as a black box, and only reads a stub file with no logic. As the stub file does not contain logic, there should be no run time associated with it.
If you are comparing the read_checkpoint time with the OOC synthesis time, then the OOC flow might not be beneficial if the run times are similar. A larger read_checpoint/open_checkpoint typically is related to constraints reading run time. Running a report_methodology, and searching the result for "runtime" might give suggestions on how to improve constraint syntax. If the OOC synthesis vs. read_checkpoint times are similar, using global synthesis might be the way to go, as cross-boundary optimization during synthesis might result in timing improvements.
I wanted to clarify on your last post with "I ran out of context synthesis for the top".The top-level of a design would need IO connectivity from a non-out of context synthesis, so it is not clear why the OOC flow is being used.
This is done because the top itself is a subblock in a larger design.
Yes the lower level design is synthesised once(Out-of-context) and stored as a design checkpoint. This is imported in my another module(top) in a generate block(mutiple such modules) each having a black_box attribute set. I am reading the checkpoint again and again for each black_box module. Also I am locking down the design to the preservation level routing. Does this help in reducing runtime? This is the actual purpose or goal.
I can try this.
