shik1997
"syntax error near" error in vivado
I am creating a full adder using verilog in vivado.
To implement various functions I am using case statement.
My code looks like this :
This is my logicunit.v file
`timescale 1ns / 1ps
module logicunit
input [5:0] input1,input2,  // inputs to ALU
input [2:0] fxn, // control signal for logical/arithmetic operation
output [5:0] result // output of alu
reg[5:0] alu_result ;
assign result = alu_result ;
wire w0,w1,w2 ; // for gteq .
wire c1,c2,c3,c4,c5,c6 ;// for adder circuit
always@(*)
begin
case ( fxn )
3'b000 :
begin
alu_result = input1 ;
$display("Input 1") ;
end
3'b001 :
begin
alu_result = input2 ;
$display("Input 2") ;
end
//3'b010 :
//begin
// ; // -A to take 2s complement exor with 1 to generate complement and add 1
//$display("Input 1") ;
//end
//3'b011 : not being used
//begin
//;  // -B
//end
3'b100 :
begin  // A >= B
twobitgteq bit01_unit ( input1[1:0] , input2[1:0] , w0 )  ;  // error comes here. It says error near twobitgteq.
twobitgteq bit23_unit ( input1[3:2] , input2[3:2] , w1 )  ;
twobitgteq bit54_unit ( input1[5:4] , input2[5:4] , w2 )  ;
alu_result = w0&w1&w2 ;
$display("Input 1 >= Input B ") ;
end
3'b101 :   // A^B
begin
alu_result = input1^input2 ;
$display("EX-OR operation on A and B") ;
end
3'b110 : // A+B
begin
sixbitadder f1 ( .x(input1[0]) , .y(input2[0]) , .cin(0) , .sum(alu_result[0]) , .cout(c1) ) ;  // error in these 6 lines also
sixbitadder f2 ( .x(input1[1]) , .y(input2[1]) , .cin(c1) , .sum(alu_result[1]) , .cout(c2) ) ;
sixbitadder f3 ( .x(input1[2]) , .y(input2[2]) , .cin(c2) , .sum(alu_result[2]) , .cout(c3) ) ;
sixbitadder f4 ( .x(input1[3]) , .y(input2[3]) , .cin(c3) , .sum(alu_result[3]) , .cout(c4) ) ;
sixbitadder f5 ( .x(input1[4]) , .y(input2[4]) , .cin(c4) , .sum(alu_result[4]) , .cout(c5) ) ;
sixbitadder f6 ( .x(input1[5]) , .y(input2[5]) , .cin(c5) , .sum(alu_result[5]) , .cout(c6) ) ;
$display("Input 1 + Input2") ;
end
3'b111 : /// A-B
begin
sixbitadder f1 ( .x(input1[0]) , .y(input2[0]) , .cin(1) , .sum(alu_result[0]) , .cout(c1) ) ;  // error here also
$display("Input 1 - Input2") ;
end
endcase
end
endmodule
Why is the error coming ?
shameera
Hi @shik1997 ,
What syntax error are you facing ? please share the error.
As you are using positional instantiation, please make sure that you are connecting submodule ports correctly.
richardhead
You can't instantiate modules inside an always block. They must be instantiated outside Theyre not like c functions, more like chips on a board.
