reduce frequency and insert to DCM
dear memeber
i try to implement this  simple system
i will take clk0 and clk90 as output
this problem appear
ERROR:NgdBuild:770 - IBUFG 'FSDDF/CLKIN_IBUFG_INST' and BUFG 'BUFG_inst' on net
   'CLK2' are lined up in series. Buffers of the same direction cannot be placed
   in series.
ERROR:NgdBuild:924 - input pad net 'CLK2' is driving non-buffer primitives:
i try to add inout buffer  and input clock buffer and follow the method here  http://www.xilinx.com/support/answers/34771.htm
same thing
please any help
my code
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
Library UNISIM;   --for including the Language template "BUFG"
use UNISIM.vcomponents.all;
entity test is
port (clk : in std_logic;     --input clock
      a2,a90 : out std_logic  --output signal which changes with "clk" signal
end test;
architecture Behavioral of test is
signal CLK2,temporal  : std_logic:='0';
signal counter : STD_LOGIC_vector(8 downto 0):="000000000";
COMPONENT DCC
 PORT(    CLKIN_IN       : in    std_logic;
          RST_IN          : in    std_logic;
          CLKIN_IBUFG_OUT : out   std_logic;
          CLK0_OUT        : out   std_logic;
          CLK90_OUT       : out   std_logic;
          LOCKED_OUT      : out   std_logic);
END COMPONENT;
begin
--------------------------REDUCE FREQU----------------------------------
    process (clk)
    begin
    if rising_edge(clk) then
    if (counter = "000110001") then  --49
    temporal <= NOT(temporal);
    counter  <= "000000000";
    elsif (counter = "000011000") then --24 half
    counter <= counter + "000000001";
    else
    counter <= counter +"000000001";
    end if;
    end if;
    end process;
------------------------------INSERT TO DCM---------------------------------
	  BUFG_inst : BUFG
   port map (
      O => CLK2,     -- Clock buffer output
      I => temporal  -- Clock buffer input
FSDDF:DCC PORT MAP(CLKIN_IN=>CLK2,RST_IN=>'0',CLKIN_IBUFG_OUT=>OPEN,CLK0_OUT=>A2,CLK90_OUT=>A90,LOCKED_OUT=>OPEN);
end Behavioral;
I am tired of the traditions of peoples --
All I want is to live freely with the girl which I love --
But this is impossible because the traditions of the people stronger than me.
The problem here is that in the DCM component, an IBUFG instance already exists. At the top level, DCM's CLKIN is mapped to CLK2, which is output from BUFG. This causes conflict since IBUFG can only be sourced from clock input pad.
To resolve the issue, you need to define the clock source as "No Buffer" in DCM clocking wizard and re-generate it.
Hi ,
Thanks for the detailed block diagram .
1) Can you send me the input frequency of the DCM and output you want to generate
Solution
While generating the DCM can you uncheck the input output buffers . By default this is checked, this means that the buffers are implemented . if this clock is connected to any output buffers this following error would appear. Do try this and let me know.
With regards
Vintu
THE INPUT FREQUENCY 50MHZ and output 5MHZe
please where can i make a change in my
code to solve the problem as ???
thank
