dlfc
vivado 2017.2.1 halt in implementation?
I am using vivado 2017.2.1 in win64 for kintex ultrascale design , for many times when the vivado running in implementation step it just halted in route , but without any error message , so i need to restart the implementation again and again to overcome the problem , some of my colleagues have the same issue , so i wonder is this a bug in vivado 2017.2.1 , how can i fix it?
thakurr
@dlfc
Which device you are using? Are you facing any issue with 2017.2?
Please have look at this AR:
https://www.xilinx.com/support/answers/69598.html
Hope this helps.
Rohit
Rohit
hemangd
Hi @dlfc
1. Please provide vivado.log file and if your implementation phase gets finish provide implementation log file.
2. And also provide environment file by running tcl command "report_environment -file <file-path>.txt" .
3. Is this a project specific issue or you are facing it in every projects?
hemangd
hemangd
prathikm
Hi @dlfc,
>>["implementation step it just halted in route, but without any error message"]
When you say it is halted, does the tool hang? What is the exact scenario? Else you should see something displayed in the tool message column or log.
- Try non-project mode temporarily to run route_design and see exactly at which phase this issue occurs and what message you get.
- Initially try changing the number of threads and jobs to run the design in tool. (AR60655)
- Share the files as mentioned above.
- If possible try the design in Vivado 2017.3.
Please mark the appropriate answer as "Accept as solution" if information provided is helpful.
Give 'Kudos' to a post which you think is useful and reply oriented.
