Voyager
Voyager
why top/bottom side bug's are usable for bottom/top side clock region resources ?
HI Friends,
I got error like PLL in bottom side should use bottom side BUFG's. why this limitation ?
How to lock and which to lock for my bottom side PLL ?
For any help or suggestions are highly appreciated.
Thank You
S Sampath
Re: why top/bottom side bug's are usable for bottom/top side clock region resources ?
HI @ssampath.
The 7-Series architecture was designed so that the top/bottom BUFG site would drive loads in this half of the device. It might be possible to use a CLOCK_DEDICTATED_ROUTE=FALSE to see what the timing degradation is, but this would only be recommended as a test. The below Clocking Resources Guide has more information on the BUFG clocking.
https://www.xilinx.com/support/documentation/user_guides/ug472_7Series_Clocking.pdf#PAGE=36
constraining cells such as PLLs or MMCMs can be accomplished with a LOC constraint. The following is an example of the syntax.
set_property LOC PLLE2_ADV_X*Y* [get_cells <name_of_pll_instance>]
As to which PLL, I would select the PLL within the same clock region as the I/O driving it.
HI @ssampath.
