Accepted Solution
2014.1 windows 8.1 MIG IP generator fails to run
Re: 2014.1 windows 8.1 MIG IP generator fails to run
Not sure if webtalk worked so here is the the generated xinfo.txt file.
From the xinfo.txt, I observed that Vivado 2013.2 is installed in your machine. So are you facing the same issue with Vivado 2013.2 as well?
Also try running vivado in 32-bit mode. below are the steps:
1. Open Command prompt
2. Navigate to <Vivado_installed_directory>\Xilinx\Vivado\2014.1 directory
3. run the command: settings64.bat
4. run the command: "vivado -m32" without quotes to invoke gui.
5. Generate the MIG IP.
Vinay
It works in 32bit mode,  I get the MIG generation tool started.  Is there a way to set Vivado up so this is the default mode so that I do not always have to go through the command prompt method to start Vivado.
Kudos: 788
Solutions: 1,015
[ Edited ]
Hi  @donsnpe ,
You can add "-m32" to the target of Vivado shortcut.
Right click on vivado shorcut in desktop, open properties and add " -m32" to the "target" field.
For example:
C:\Xilinx\Vivado\2014.1\bin\unwrapped\win64.o\vvgl.exe C:\Xilinx\Vivado\2014.1\.\bin\vivado.bat -m32
Below is the snapshot showing the same.
After this change, when you invoke vivado, it will be opened in 32 bit mode.
Hope this helps.
Deepika.
Deepika.
