Abdul_Qayyum
Account has failed export compliance verification
Hi Team,
I am trying to download the Board File for ZC706 and getting the error "Account has failed export compliance verification". Please provide the solution. Also check the screenshot weather I am filling the Form correctly or not.
Best Regards,
Abdul Qayyum.
bruce_karaffa
Have you searched the forums for similar posts?  You should come across this Answer Record.  https://www.xilinx.com/support/answers/44043.html
bruce_karaffa
ansarimo
Hi @Abdul_Qayyum,
As correctly indicated by @bruce_karaffa , please follow the AR.
Also, send an email to Xilinx Customer Support (websupport@xilinx.comindicating your "export compliance" issue and they, in turn, will contact the Xilinx Global Trade Compliance team on your behalf, who would be able to screen and verify your profile and if all is good, re-activate this then, so that you can then login and download the required software without issues.
Hope this helps.
Thanks and Regards,
Ansari Hunen
Don’t forget to reply, kudo, and accept as a solution.
