BitStream Generation failed in vivado. !
I configured the single ethernet in vivado using AXI 1G/2.5G Ethernet subsystem. When I try to generaet the bitstream am failing with the following error.
[Common 17-69] Command failed: This design contains one or more cells for which bitstream generation is not permitted:
design_1_i/axi_ethernet_0/U0/mac/U0/tri_mode_ethernet_mac_i/bd_929b_mac_0_core (bd_929b_mac_0_tri_mode_ethernet_mac_v9_0_12)
If a new IP Core license was added, in order for the new license to be picked up, the current netlist needs to be updated by resetting and re-generating the IP output products before bitstream generation.
Please help me in this. Thanks in advance.!!
The Block design screen shots is attached here. PFA.
Re: BitStream Generation failed in vivado. !
Hi @kiran.jaragappala ,
This can happen if you generate an IP core with an sim-only license and then purchase or install a hw evaluation or full license but do not regenerate the IP core.
Also chekc the below AR#:
https://www.xilinx.com/support/answers/58758.html
Raj
Raj
Thank You.
Do you have further queries on this? If not, please close this thread by marking it as accepted solution.
Raj
