Observer scy86dev
Can't locate yum packages for missing libraries needed by Vivado (CentOS7)
I just finished installing Vivado and ran this perl script which helps in picking up libraries I may be missing on my CentOS7 system. It indicated that I had three missing libraries (librdi_commonmain.so, libboost_signals.so, librdi_common.so).
/lib64/libpthread.so.0
librdi_commonmain.so => not found
libboost_signals.so => not found
/lib64/ld-linux-x86-64.so.2
/lib64/libgcc_s.so.1
/lib64/libtcmalloc.so.4
linux-vdso.so.1
/lib64/libc.so.6
librdi_common.so => not found
/lib64/libstdc++.so.6
/lib64/libm.so.6
I was able to find package solutions for the "libboost_signals.so".
user@host~ yum provides '*/libboost_signals.so'
Loaded plugins: fastestmirror, langpacks
Loading mirror speeds from cached hostfile
 * base: centos.host-engine.com
 * elrepo: elrepo.org
 * epel: mirror.colorado.edu
 * extras: centos.host-engine.com
 * updates: centos.host-engine.com
boost-devel-1.53.0-27.el7.i686 : The Boost C++ headers and shared development libraries
Repo        : base
Matched from:
Filename    : /usr/lib/libboost_signals.so
boost-devel-1.53.0-27.el7.x86_64 : The Boost C++ headers and shared development libraries
Repo        : base
Matched from:
Filename    : /usr/lib64/libboost_signals.so
boost148-devel-1.48.0-7.el7.x86_64 : The Boost C++ headers and shared development libraries
Repo        : epel
Matched from:
Filename    : /usr/lib64/boost148/libboost_signals.so
However, for the other two libraries I was not able to find anything. Does anyone know the packages for the other two libraries (librdi_common.so, librdi_commonmain.so) because yum isn't showing anything at the moment...
user@host~ yum provides '*/librdi_commonmain.so'
No matches found
user@host~ yum provides '*/librdi_common.so'
No matches found
Cheers~S
Re: Can't locate yum packages for missing libraries needed by Vivado (CentOS7)
