[Common 17-69] Commad Failed
I have met a problem when I wanted to generate the bit-stream of block design, which is about the kcu105 FPGA and ADFMCDAQ2:
[Common 17-69] Command failed: This design contains one or more cells for which bitstream generation is not permitted:
i_system_wrapper/system_i/axi_ethernet/inst/eth_mac/inst/bd_55cd_eth_mac_0_core (tri_mode_ethernet_mac_v9_0_5)
i_system_wrapper/system_i/axi_ad9680_jesd/inst/i_system_axi_ad9680_jesd_0 (jesd204_v7_0_1_top__parameterized0)
i_system_wrapper/system_i/axi_ad9144_jesd/inst/i_system_axi_ad9144_jesd_0 (jesd204_v7_0_1_top)
I source the library of ADFMCDAQ2 from Analog Wiki, and also, I already install the related license
Can anyone help me with that ?
Thank you so much!!!
Re: [Common 17-69] Commad Failed
Hi @yzzhsx12345
From the Xinfo you shared, it is clear that you have "Design linking" license for tri-mode ethernet IP for which bitstream is not permitted. Refer https://www.xilinx.com/support/answers/22108.html
This is the reason of the error during bitstream. I would suggest you to get Evaluation license for the IP and install it correctly. I believe it should resolve the error.
https://www.xilinx.com/products/intellectual-property/temac-order.html
The Critical warning is telling that your timing of the design is not met. This is different issue all together and not related to licensing.
Rohit
Rohit
@yzzhsx12345
Refer this AR:
https://www.xilinx.com/support/answers/58758.html
Rohit
Rohit
@yzzhsx12345,
Can you please run the following TCL command from Vivado TCL console and share the generated output file (system_info.txt)?
  • report_environment -file sytem_info.txt
After running the command just type “pwd” this will show you the path where the system_info.txt file is generated. You can browse to that path from windows and find the file.
--Syed
Sure, here you go
Hi @yzzhsx12345,
Have you gone through the AR#58758 ? Did it not resolve the issue ?
Thanks & Regards,
A.Shameer.
Yes, I did follow the step of what AR #58758 talks about, but here is another one error and one critical warning appears, I am not sure if is still the reason that I didn't get the correct Evaluation license or I need to do other steps..........?
Please help me with that , Thank you!!
Thank you give me the reference, which I have followed, but it looks like I met another problem attached, I am concerning if it is because I need other related license or because of other reasons.
Can you help me with that ? Thank you !
Hi @yzzhsx12345
Rohit
Rohit
Thank you! My problem was successfully solved by following your instruction !
