ERROR:Security:12 - No 'xc3s5000' feature version 2013.10 was available (-5)
I have a problem in my Xilinx. I'm using ISE Design Suite 14.7 and started 30day evaluation.
when I run(implement top module) I get this error below.
Release 14.7 Map P.20131013 (nt64)
Xilinx Mapping Report File for Design 'efe'
Design Information
Command Line : map -intstyle ise -p xc3s5000-fg900-4 -cm area -ir off -pr off
-c 100 -o efe_map.ncd efe.ngd efe.pcf
Target Device : xc3s5000
Target Package : fg900
Target Speed : -4
Mapper Version : spartan3 -- $Revision: 1.55 $
Mapped Date : Sat Nov 18 22:31:44 2017
Design Summary
Number of errors : 1
Number of warnings : 0
Section 1 - Errors
ERROR:Security:12 - No 'xc3s5000' feature version 2013.10 was available (-5),
ERROR:Map:258 - A problem was encountered attempting to get the license for this
architecture.
Section 2 - Warnings
WARNING:Security:9b - No 'ISE' feature version 2013.10 was available for part
'xc3s5000'.
Section 3 - Informational
INFO:Security:56 - Part 'xc3s5000' is not a WebPack part.
INFO:Security:61 - The XILINXD_LICENSE_FILE environment variable is not set.
INFO:Security:63 - The LM_LICENSE_FILE environment variable is not set.
INFO:Security:68 - For more information or for assistance in obtaining
INFO:Security:68a - user is JAEWON, on host PCNAME.
I don't know how to fix this. Does anyone know the solution?
Sincerly
Jaewon Kim
Re: ERROR:Security:12 - No 'xc3s5000' feature version 2013.10 was available (-5)
 Hello @kimjaewon,
As already correctly indicated by other colleagues, as you are using a xc3s5000 in ISE, to successfully work with this device in ISE, you'd need a full ISE license for this, as there is no longer ISE 30-days evaluation license available. Yes, there is Vivado HLS and Vivado System Edition 30-days evaluation licenses, however these won't work for you in ISE.
How to get a full ISE license?
You see, these days, when you purchase a Vivado license, an ISE license comes with this license (not in the Vivado license itself, but as a separate license altogether) for free.
Therefore, in order to obtain an ISE license, if you have already purchase a Vivado license, you'd then have received an ISE license of the same edition for free, that’d have been added to you licensing account.
If you haven’t purchased any Vivado related licenses yet, and no plans in buying one any soon, then another suggestion for you is to switch to a smaller Spartan 3 device which is a support by ISE WebPACK license device (e.g. Spartan-3 FPGAs: XC3S50 – XC3S1500. For more supported by ISE WebPACK devices please see this pdf file: https://www.xilinx.com/publications/matrix/Software_matrix.pdf ). In this case, you can then generate and use an ISE WebPACK license for this. With that license and smaller device (e.g. XC3S1500) you’d then be able to overcome this issue.
Hope this helps.
Kind Regards,
Anatoli
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Hi @kimjaewon,
There are two issues here.
1. The device which you are targetting is not supported by ISE webpack. ( Check this link for supported devices https://www.xilinx.com/publications/matrix/Software_matrix.pdf
2. And the license which you have added does not have ISE webpack feature. It shows that the license is for Vivado HLS.
You need to get the ISE webpack license from the Xilinx licensing website.
( Check this link for it https://forums.xilinx.com/t5/Installation-and-Licensing/Finding-ISE-webpack-license/td-p/758406 )
hemangd
hemangd
Don't forget to give kudos and mark it as accepted solution if your issue gets resolved.
Mentor
Mentor
Try setting the environmental variable
set XILINXD_LICENSE_FILE=c:\.Xilinx\Xilinx.lic
Also, check inside the license file to see if the xc3S500 feature exists in the file.  Also,  set your target device to a smaller Spartan3 device..   Does it work then?
It looks like you may have more than one license on your computer, in particular, you might have a Webpack license, and it's finding this one before the 30 day eval license.
Can you check if your system date and time are correct?
As per the xinfo and license file the start date is March 5th 2015, your system date should be greater than this inorder to use the license.
From the xinfo file the system date today seems to be 28th Feb 2014. If this is true please set the correct system date and restart ISE. See if this helps.
you may open license file in words and check dates
Thanks and Regards
Balkrishan
Hi @kimjaewon,
The Xilinx.lic attached shows this is Node-locked Vivado HLS 30-day evaluation license (As suggested by @hemangd). Also ISE Webpack does not support xc3s5000 device as per software matrix. You need a Design Suite to run it.
Please mark the appropriate answer as "Accept as solution" if information provided is helpful.
Give 'Kudos' to a post which you think is useful and reply oriented.
 Hello @kimjaewon,
Hope this helps.
Kind Regards,
Anatoli
Kind Regards,
Anatoli Curran,
