thirdeye
FlexLM license server installation setup configuration guide
I just struggled through setting up my licenses for ISE 11 Design Suite. After contact with my FAE and opening a Webcase I now reflect on this process as rather simple, but the lack of basic information made this process much harder for me than it should have been.
Here is my attempt at the guide I feel Xilinx should have included with the FlexLM license server download.
FlexLM License Server Installation Configuration Setup Guide for Xilinx ISE 11 Design Suite
Note: FlexLM is needed for floating licenses not node-locked ones.
Other Documents:
·         ISE 11 Installation Guide
o    http://www.xilinx.com/support/documentation/sw_manuals/xilinx11/irn.pdf
·         The FAQ (more in depth information)
o    http://www.xilinx.com/tools/faq.htm
Setup Basics:
·         FlexLM server runs on any machine (not necessarily a development machine)
·         Xilinx License Configuration Manager (XLCM) connects to server and provides licenses to tools
Generating Licenses:
·         Xilinx Product Download and Licensing Site (Entitlement Center) where you may download, install or license products: http://www.xilinx.com/getproduct
·         Licenses must all be in one file
o    Ideally when generating the license file from the entitlement center you chose (checkbox) all of your available floating licenses and then generate a single license file for all of them at once.
o    This can be done manually by copying the data into one file and excluding additional “server” lines (server line should be identical because the licenses are locked to a single machine).
·         Floating licenses must be generated for the server machine (OS, HostID)
o    Assuming your server is not a development machine it will not have the Xilinx tools and therefore not have XLCM
o    Instead, on a Windows machine, run CMD and run the command “ipconfig/all” which will give you your MAC address (listed here as “Physical Address”) along with your IP information. Be sure you are looking at the hardware that provides your network connection; many computers have multiple network cards these days. This Physical Address should be listed under the same peripheral as the IP address of your computer. This must be done on the server to get the MAC address of the server since the license is to be locked to the server. The MAC address should be displayed as XX-XX-XX-XX-XX-XX.
§  For generating the license choose “MAC Address” as the HostID option and enter the value from the CMD window. Enter it without dashes, ie: XXXXXXXXXXXX.
·         The license file gets emailed to the user, but can also be downloaded from the entitlement center once generated.
Setting Up the Server
·         As implied above, the server can be run without having to install ISE Design Suite. This allows it to be run on virtually any machine, ideally an actual server that will be on all the time as opposed to someone’s development machine.
·         The server does not need to be “installed” in the Windows sense, the executables are merely placed where desired and run.
·         From download.xilinx.com -> Login to start downloading.  You will see a section in tab "1. Download Software" that states "License Server Utilities”.  Click on this and select the files for the appropriate OS. This will include an archive of the executables.
o    These executable are standard with FlexLM.
§  Lmgrd.exe – To get the server running, you should only use lmgrd.
§  Xilinxd.exe is the actual license daemon, and needs to be available to lmgrd to call.
§  The other tools are additional tools for advanced Flex users only.
·         Lmutil.exe is for debugging, Xilinx created Xilinx License Configuration Manager (on the client side) to give you a GUI that provides the functionality of this command line tool.
·         Lmtools.exe is currently unsupported by Xilinx and is used to run Windows Services.
o    I configured my license server to run using Lmtools.exe
o    However, I recommend the bat file because lmtools is not straight forward despite the fact that it is a GUI.
o    The server runs on startup and no CMD window opens, but when I login using remote desktop, a CMD window opens although the server is already running.
·         Place the executables where desired and simply launch the server using the command line."
o    Simplest command:
§   "lmgrd –c <LICENSE_FILE_PATH>"
o    Supposedly using a log file suppresses the CMD window.
§  "< Server Tool directory>\bin\nt\lmgrd -c <path_to_license>\Xilinx.lic –l <path_to_license>\log1.log"
o    I wrote  LaunchServer.bat file (this can then be added to the startup menu on a Windows server) with the command:
§  "start C:\Xilinx\Xilinx_flexlm_v11.6\lmgrd.exe -c C:\Xilinx\Licenses\Xilinx.lic –l C:\Xilinx\Licenses\log.log"
o    As seen above, ‘-c’ indicates the license file path comes next; likewise ‘-l’ indicates that the log file path comes next.
·         More information on the command line:
o    http://www.simulia.com/support/flexlm92/chap6.htm
o    This guide seems to say that you can list multiple license files so combining may not be required. You may only run a single copy, but perhaps you can add multiple license files to be served.
Using a License from the ISE Suite using Xilinx License Configuration Manager (XLCM)
·         Upon launch of an ISE tool (ISE, EDK, etc) the program will check for a valid license. If there is none it will open XLCM. XLCM can be opened from within the programs on the help menu by choosing “Manage License”.
·         In XLCM the example paths are simple, but not entirely clear.
o    The license server runs on a specific port (my default was 2100)
§  This is stated in the license file in the form:
·         SERVER servername XXXXXXXXXXXX port
§  The addition to the license paths should be:
·         Port_num@server_name;
·         ie: 2100:licsrv;
o    I added this entry to both paths listed in the manager. This may not be necessary.
·         Once the server is added to the path the license window should refresh and you should see the licenses there that are served by the server. You should now be able to use them seamlessly.
·         Close XLCM and the tools and re-launch the tools to see if the license is acquired.
I hope this information is helpful to others in the same position I was just in. Please post your experiences if you have additional or contradicting information.
Josh
Message Edited by thirdeye on 10-13-2009 12:02 PM
Message Edited by thirdeye on 10-13-2009 12:09 PM
kpatel
Thanks Josh,
I'll have this reviewed.  We always appreciate customers helping us make our docs more clear.
Kamal Patel
Product Applications Manager
Worldwide Technical Support
thirdeye
Here is the same information in a pdf for easy access.
Josh
Message Edited by thirdeye on 10-13-2009 12:10 PM
kpatel
Thanks Josh,
Kamal Patel
thirdeye
Great, glad to hear that.
Josh
lordgalloth
maybe I am blind and missing obvious, but I can not find the the License ServerUtilities. Is there any other requirements for seeing this link? Is it possible that the link is vissible only to the person, who bought the ISE through the webpages, or somethink like that?
I just need to download correct flexLM server.
Thank for your answers
Jan
thirdeye
lordgalloth wrote:
Jan
 Yes, you must be the license/account administrator or have access provided by the administrator. I cannot see the server utilities myself. I login as my co-worker and I can see them. Interesting because I can download ISE, etc from my account and I can generate IP licenses, but I cannot see or generate ISE licenses nor can I see or download the license server utilities.
If you do have this permission go to:
http://www.xilinx.com/support/download/index.htm
and under 1 click "Login to start downloading >>"
Once you login you can see what you are entitled to. The license server utilities will be at the bottom of the screen. See the attached image.
Also be sure that you have the correct account selected. My co-worker, whose account the licenses are linked to, has two xilinx accounts. I could not find the correct licenses to generate because I was looking under the incorrect account.
You can have the account administrator add you to their account as a user or as an administrator. You may be able to download the license server and generate license files as a mere user of the account, but I am not sure about this as I have not done it. My co-worker allows me to just login as him to download the files so that he does not have to do it for me.
So yes, the licenses and license server utilities are only visible to one account. That account is almost definitely the person who ordered the software. See if they can add you as a user and you can access them this way. If this works please let me and others know so we may use this method in the future.
Good luck,
Josh
Message Edited by thirdeye on 10-20-2009 09:53 AM
deanmiller
Even with this, we could not get a floating license to work.  Best give up and use node-locked licenses.
mlakata
Xilinx has to have the worst user satisfaction of any company I've dealt with. but anyways...
The FlexLM tool downloads are hidden.  They are NOT listed for the 13.2 release of the tools, but they are listed for the 13.1 release. However, if you are using a browser such as Mozilla Firefox, you will not be able to scroll the window to see them!
1. Use Internet Explorer
2. go to http://www.xilinx.com/support/download/index.htm
3. click on "13.1" on the left,
4. scroll down and find the License Manager tools
5. then you will be prompted to log in, so make sure you have an account already. It is unclear if you need special permission or not.
eteam00
Instructor
Instructor
FYI, I am running Mozilla 6.02 on Win Vista x64, and I have no trouble with window scrolling on the ISE tools download pages.
-- Bob Elkind
SIGNATURE:
Summary:
adidas
Searched high and low for version information required for FlexLM licensing
http://www.xilinx.com/support/answers/5332.html
http://www.xilinx.com/support/answers/33022.html
FlexLM was owned by Globetrotter then Macrovision, now Flexera
Why does Xilinx not list the minimum requirements for the Floating License server? According the Whats New in ISE Design notes --- FlexNET support began in version ISE Design Suite 11.1
http://www.xilinx.com/support/documentation/sw_manuals/xilinx11/whatsnew.htm
Is only version 11x supported?
What about legacy versions such as 8.2a or 10.13?
Shan
adidas
Oops forgot to include product (purchased) that we are attempting to license
Vivado Debug Standalone (includes ChipScope Pro), Floating License
thirdeye
The floating licenses are only for newer versions of ISE. I used to use ISE 9.x and ISE 10.x and the license was a part of the installation, you just installed and it worked - no external license. Since you are trying to license Vivado this is irrelevant.
The license server can be downlaoded from the same location as the tools themselves.
I doubt your PC/ server does not meet the minimum requirements for running th FlexLM license server.
What exactly is your question?
Have you set it up and it does not work?
Josh
adidas
Hello!
Thank you for you reply - We have (2) existing FlexLM servers for products such as COSMIC compiler
An end user notified us (Helpdesk) that a FlexLM server was needed for a product just purchased - Xilinx ChipScope
Will our existing servers be able to support the Xilinx Floating License?
Existing server versions are 8.2a (Globetrotter LMTOOLS) and 10.13 (Macrovision LMTOOLS)
Thanks again,
Shan
thirdeye
@adidas wrote:
Hello!
Thanks again,
Shan
Unfortunately I do not know these answers, but I believe they will support it.
Hopefully Xilinx or someone who is sure will give you some more information.
I have had issues with conflicting FlexLM licenses, but only with environment variables (since multiple applications that use FlexLM licenses use the same environment variables = horrible design idea) and dongles since only a single dongle is supported on one machine at a time (also a horrible design decision).
Good luck!
Josh
barmaley
Some additional information.
Tried installing license server on Linux machine while having clients on Windows. It did not work properly. Next, I tried installing Samba which would allow Linux to be part of the Windows group and etc. But it still would not work properly. I guess FlexLM does not work smoothly in multiple OS configurations. I guess the license server and clients have to be on the same operating system. Just word of advise to stay away from such configurations.
Cheers,
Kirill
