Have a original vivado .lic file. Still license error occurs
I have a original vivado license file which i got the with the Artix 7 FPGA board. After installing the license, i can see that the Expiration date is set to "Permanent" in the license manager. But still i get this error while running the simulation or synthesis.
ERROR: [Simtcl 6-50] Simulation engine failed to start: A valid license was not found for simulation. Please run the Vivado License Manager for assistance in determining which features and devices are licensed for your system.
Thanks for the help in advance.
Hello @sandy_1022,
From the env_new.txt file attached in your earlier post, it seems that there is hostID mismatch between your system's hostID and the one for which license is generated. The hostID of your system is ee3b549 and the one in license file is a683ff30. You need to re-host the license for your system by following below AR
http://www.xilinx.com/support/answers/36136.html
Let us know if you face any problems after rehosting license.
Ashish
Hi @sandy_1022,
Welcome to Xilinx Forums Community.
Please share the .lic file and output xinfo.txt of following command in Tcl console.
report_environment -file xinfo.txt
Which device you are targeting?
Arpan
Arpan
Thanks a lot for the quick response. I'm very glad.
Please find the response i got from tcl console.
I have also attached the .lic file for your refenrence.
INFO: [Common 17-635] Now fetching report information. This may take some time.
INFO: [Common 17-633] Fetching system information...
INFO: [Common 17-632] Fetching software environment information...
INFO: [Common 17-629] Fetching Vivado preferences...
INFO: [Common 17-630] Fetching installation information...
INFO: [Common 17-628] Fetching DLL information...
INFO: [Common 17-631] Fetching license information...
INFO: [Common 17-634] Done fetching report information.
I'm sorry. I didn't get you about the device. I have created a project using ISE Xilinx  Design suite 14.7 and i am using the same file to run on Vivado 2015.4  for FPGA implementation. .
Thanks in advance for your help.
do you have any solution for me please?
Tags (2)
@sandy_1022,
Share the xinfo.txt as well!
To generate xinfo.txt, Click Start -->Xilinx Design tool--> ISE design entry 14.x --> Accessories--> Xinfo System checker
You can also generate same from Vivado by running the below command in Vivado TCL console:
report_environment -file <path>/xinfo.txt
Your license can be using for XC7A200T only.
--Syed
Hi @syedz
Thanks for your response.
If i run the tcl console i get an error like this.
ERROR: [Common 17-37] Directory in which file xinfo.txt is to be written does not exist [<path>]
but this what i got from the other option you mentioned(start menu). But again i think this is for 14.7 ise design suite which is also installed in my system and not for vivado because i didnt find accessories under vivado directory. I have attachede both pics for your reference.
Also you might be right about the device. It is mentioned in the FPGA kit that it is set to xc7a200T only.
what should i do now?
thanks for your response
Hi @syedz,
After you mentioned, about the device
l also tried changing the decive to xc7a200t. But i still get the same license error which i got previously.
Do i need to specify a specific device or any device under Artix 7 family works? Because my board is a Artix 7 fpga c701 kit.
Thanks again,
Sandy
Hi @sandy_1022,
<path>/xinfo.txt
Here <path> means something like C:/Users/..
else just run
and attach xinfo,txt here.
Arpan
Arpan
Hi @arpansur
please find the result i got by running    report_environment -file xinfo.txt
Thanks again for helping me,
Sandy
Hi @sandy_1022,
The outputs will be written to xinfo.txt file. Please attach that file.
Please use the following Tcl command to get the location where the xinfo.txt file is saved.
pwd
Arpan
Arpan
@arpansur
I'm sorry i didn't get you the first time.
Please find the text file attached.
Sandy
hi @sandy_1022
From the xinfo file that you have attached there is no Vivado license installed on your machine.This is the reason for what you are seeing during simulation.
Please install the license properly by following below steps.
Open Vivado License Manager -> Load License -> Copy License and point to the directory where this device locked license is present.
Now restart Vivado and run simulation with part XC7A200T-2FBG676C.
Hi @pulim
I'm not getting the part   XC7A200T-2FBG676C  that you have mentioned in your post.
Please find the pic attached.
Also i had got the same message when i loaded the License file previously too. It said license attached successfully.
Can you think of any other problem? I also read this other post where it was a floating license. Am i having the same problem?
Sandy
Hi @sandy_1022,
Just as a debugging step:
Can you please try running a small design with XC7Z010 and let us know the outcomes.
Arpan
Arpan
Hi @arpansur
I'm still facing the same error as before.
Hello @sandy_1022,
From xinfo, It seems the license which you have installed is different than the one which you have attached in this thread. (Start date and version limit is different), can you point the directory name of attached Xilinx.lic to XILINXD_LICENSE_FILE variable after clicking "Manage License Search Paths" in Vivado License Manager? Then click on 'Set' and check with any webpack device.
Ashish
Also, after implementing Ashish's suggestion, please run the following command in tcl console and share the generated env_new.txt file:
report_environment -file env_new.txt
Also, run an example design to see if it is working.
Also, can you tell us if you installed the webPACK edition or the System edition of Vivado?
Nupur
Hi @sandy_1022,
You can search device  XC7A200T-2FBG676C using the following format
XC7A200TFBG676-2
Arpan
Arpan
Hi @sandy_1022
Please check arpan's suggestion on how to select that device.
Alternatively, you can also select it using the drop down menu. (PFA)
Tushar
Hello @sandy_1022,
Any update on this Licensing issue. Hope the above shared suggestions were helpful.
Let us know if you are still facing any Error.
--Syed
Hi @ashishd
I'm sure its the same License file. But i will attach it again for your reference.
Also set XILINXD_LICENSE_FILE to file path as shown in the snip.
Thanks for you continuous help,
Sandy
Hi @nupurs
Please find the text file i got by running the   report_environment -file env_new.txt  command in tcl console.
I ran a simple AND gate code which works perfectly fine in ISE 14.7(checked)(Code attached)
I installed a SYSTEM EDITION
module and_gate(
input [4:0] a,
input [4:0] b,
output [4:0] c
assign c=a&b;
endmodule
module and_g_tb;
// Inputs
reg [4:0] a;
reg [4:0] b;
// Outputs
wire [4:0] c;
// Instantiate the Unit Under Test (UUT)
and_gate uut (
.a(a),
.b(b),
.c(c)
initial begin
// Initialize Inputs
a = 0;
b = 0;
// Wait 100 ns for global reset to finish
#100;
a=00010;
b=00110;
#50;
a=0111;
b=1000;
// Add stimulus here
end
endmodule
Hi @arpansur
Hi @tusharvi
Thank you , i found the device.
Please find attached for confirmation.
Hi @syedz
Yes. After having done all the above changes, i'm still facing the License errors.
I have attached a copy of it below.
Thanks all for the continuous help,
Hope we can fix it out .
Sandy
Hi @syedz
@tusharvi
@arpansur
@nupurs
@ashishd
I will also attach the xinfo.text file for your reference.
Sandy
Hello @sandy_1022,
Ashish
Hi @ashishd,
I think i know why that happened. This License file was downloaded by my friend on his PC. Can we not share the same License file in multiple PC's? Both of us need to use vivado 2015.4 for our projects using the same ARTIX 7 fpga c701 board.
Sandy
.Hi Sandy,
In case of activation based licenses (Vivado), if the license is nodelocked, it can only be used for the machine on which the license creation request was generated. An exception to this is Webpack license which can be used on multiple machines as it won't have a host id attached to it.
Can you please let us know the details of the license you are trying to use?
Edit: I just saw your initial note and noted that you are using the license that you obtained with Artix 7 FPGA board
If you are using this license, it can only be used on a single machine.
Tushar.
Hello @sandy_1022,
Since this is device locked license (non-webpack), it can't be shared. You need to rehost it by following AR mentioned in my earlier post.
Ashish
Hi @sandy_1022,
You can download webpack license for your system using VLM. XC7A200T is supported in Vivado 2015.4 webpack devices.
Please go through page 15 of following link for the same information.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug973-vivado-release-notes-install-license.pdf
To download webpack license for Vivado please go through following steps.(Go through the attachments)
After clicking on "Connect Now" you will be directed to Xilinx Licensing site.
Login with your credentials and get the license.
Please let us know if you are facing any problem in downloading webpack license.
Arpan
Arpan
@arpansur
Should i be using certificate based license or activation based license for obtaining web pack license?
and which among those options?
I just want to be extra careful this time with the license file.
Sandy
