u24c02
I can't download the ISE Webpack.
Hi I'm trying to download the ISE webpack, But it still show the message as bwlow.
Does any one know how o resolve this problem?
Error
We cannot fulfill your request due to technical difficulties. Please try again later.
u24c02
Does anyone know what is the problem?
arpansur
Hi @u24c02,
Which link you are using?
Please file a download woraround request in Xilinx Service Portal.
Arpan
u24c02
I use that this link http://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/design-tools.html
Full Installer for Windows (TAR/GZIP - 6.18 GB)
MD5 SUM Value: 94f40553a93dfbeca642503e2721b270
arpansur
Hi @u24c02,
I am not seeing any issues with the link.
Can you please try clearing the cache or open the link in incognito window?
Arpan
u24c02
I 've got a message as below.
We cannot fulfill your request as your account has failed export compliance verification. Please visit http://www.xilinx.com/support/answers/44043.html for a possible solution to resolve this error.
What does this mean?
u24c02
I can't find any wrong point. Would you please let me know? any hint?
arpansur
Hi @u24c02,
Did you went through the link http://www.xilinx.com/support/answers/44043.html
Arpan
u24c02
Hi.
I have not a company then is this available to use ISE webpack?
syedz
@u24c02,
The AR not only mentions about the company but also on export control policy, Check if you fall under E or D category countries,
Try Filling the form : http://www.xilinx.com/support/service-portal/reporting-issues.html
--Syed
u24c02
This is of mine
u24c02
syedz
@u24c02
Did you fill the form : http://www.xilinx.com/support/service-portal/reporting-issues.html
--Syed
arpansur
Hi @u24c02,
Please share your user-ID and email-ID used for Xilinx Account
You can send a private message.
Arpan
arpansur
Hi @u24c02,
It seems your issue is resolved.
Please close this thread.
Arpan
karemzaky
i have the same problem
