oscarcalvogarcia
I can't use a Reed Solomon Permanent license I have bought
I downloaded an eval license of Reed Solomen encoder and decoder, and I could use this license without problems.
After that I have bought a permanent license of Reed Solomon encoder and decoder and I erase eval license and add permanent license in C:\.Xilinx but Xilinx License Configuration Manager don't detect permanent license (if I change and add eval license , License Manager detect eval_license and I can work with eval license but I can't work with permanent license).
Permanent license:
SERVER id-10504 002215c023d0 2100
USE_SERVER
VENDOR xilinxd
# This is a permanent license generated on Wed Mar 24 15:15:04 GMT+00:00 2010
Also if I put '#' before USER_SERVER, then Xilinx License Configuration Manager detect permanent license but when I want to create a core in my project, then system say me that they don't found any license for rs_encoder component
I don't know why if I have paid for the permanent license I can't use it.
Please help me
This is from the Error Message
Release 11.5 - Xilinx CORE Generator IP GUI Launcher L.70 (nt)
Copyright (c) 1995-2009 Xilinx, Inc. All rights reserved.
No license for component <rs_decoder> found. You may use the customization GUI
for this component but you will not be able to generate any implementation or
simulation files. For license installation help, please visit:
www.xilinx.com/ipcenter/ip_license/ip_licensing_help.htm For ordering
information, please refer to the product page for this component on:
www.xilinx.com Cancelled Customization.
IP creation cancelled.
davidch
You're using a floating license as if it were a node locked license.  Change it to a node locked license or launch the license server using the lmgrd -c xilinx.lic -l logfile.log command.
davidch
