Newbie deszka
I get "ERROR: This installation is not supported on 32 bit platforms." on a 64 bit platform
Debian Jessie 64 bit system. When running the Linux installer ./Xilinx_Vivado_SDK_2015.1_0428_1_Lin64.bin it prints Even after removing i386 support from multiarch, including every 32 bit package, the installer greets me with this error.
Visitor dasidler
Re: I get "ERROR: This installation is not supported on 32 bit platforms." on a 64 bit platform
Apparently the xsetup script uses "uname -i" which returns "unknown" on my Arch linux installation.
But if you know that you have an x86_64 system, you can simply comment out the check in the xsetup file, installation goes file and it seems also that vivado & vivado hls work fine that way.
Debian is unsupported OS and we have not tested Vivado on Debian.
Try using supported OS.
Microsoft Windows Support
• Windows 7 and 7 SP1 Professional (64-bit), English/Japanese.
• Windows 8.1 Professional (64-bit), English/Japanese.
• Vivado® Lab Edition is the only Xilinx toolset that supports Windows 7 SP1
Professional, 32-bit Operating System. Lab Edition also supports the 64-bit systems.
Linux Support
• Red Hat Enterprise Workstation 7.0 (64-bit)
• Red Hat Enterprise Workstation 6.4-6.6 (64-bit)
• SUSE Linux Enterprise 12.0 (64-bit)
• Cent OS 7.0 (64-bit)
• Ubuntu Linux 14.04 LTS (64-bit)
• Vivado Lab Edition is the only Xilinx toolset that supports the Red Hat Enterprise
Workstation
Thanks,Vijay
This might be an unsupported OS, but uname -m is the right command to check the architecture ;).
Best Regards,
Stephan
Yap!
I am running Arch Linux too. Solved the problem by:
1\ starting the installer with the --confirm parameter , path to the xsetup file got displayed
2\ finding and modifying the xsetup file (uname -m).
3\ confirmed the execution of xsetup in the installer shell.
Worked fine!
Although it's possible to install Vivado 2015.1 on 32-bit OS, it's not recommended to use in that way
1. No test has been made on these unsupported OS by Xilinx
2. Limit on physical memory for 32-bit OS hinders the performance.
Nobody said that someone installs Vivado 2015.1 on 32-bit platform. However, the usage of 'uname -i' in xsetup is wrong and should be replaced by 'uname -m'. The first one returns the hardware platform (e.g. GenuineIntel, AuthenticAMD, ...) and the latter one returns the machine hardware name (e.g. i386, i686, x86_64, ...).
Visitor ldp
tud_hartmann is right, it is correct solution.
Visitor emeyer
I had the same issue to install Vivado or to install SDK separatly. A colleague from software staff found a solution. In Debians, their is an uname working well (at least for "-i" otpion):
 $ /usr/lib/klibc/bin/uname -i
Solution :
 $ sudo dpkg-divert --add --rename --divert /bin/uname.orig /bin/uname
 $ sudo ln -s /usr/lib/klibc/bin/uname /bin/uname
To go back :
$ sudo dpkg-divert --rename --remove /bin/uname
sources: https://bugs.launchpad.net/ubuntu/+source/coreutils/+bug/470550
Newbie flamingo2
I have downloaded the Linux 64 bit installer (.bin). I am running on a supported 64 bit Linux (Ubuntu 14.04). I am getting this same error. Is there a workaround? I saw mention of a command line option, but I haven't found documentation for that. (Not really sure where to look.) I am running a VMware Ubuntu 14.04.3 (Trusty Tahr).
Visitor emeyer
Hello flamingo2,
Have you this /usr/lib/klibc/bin/uname version on your system ? If yes, does the command answer like this :
x86_64
In this case and if you have root permissions , you can apply the solution posted on ‎12-07-2015. After that, execute again the Vivado Linux 64 bit installer. It should work.
Hope this will help you
emeyer
Newbie flamingo2
Turns out that I was wrong? The vmdk for Trusty Tahr at osboxes seems to have a 32 bit kernel. It is identified as "VMware (VMDK) 64bit Size: 760.2MB", but identifies as i686. I'm required to run Ubuntu 14.04, so I'm going to see if I have the same problem on VirtualBox VM. Thanks for the reply.
Newbie nickoe
This workaround indeed works fine. Xilinx should really fix that script :)
Xilinx still needs to fix that script.  Come on guys - it's not even one line of code and the fix has been known for months...
Hi All,
I created a change request CR#930032 to address this issue.
Vinay
Visitor henry_kh
Not fixed yet in 2016.2... this is such an easy fix for Xilinx to make, and probably wastes an hour or two for every user that encounters it for the first time.
