ISE 14.7
Hi, I use to work with the ISE 14.7 in the VM Box for windows 10.
It's fine and great, but with the latest windows 10 update version 20H2 the ISE VM must be removed as no more compatibility.
I still working without updating the Windows.
Please a roundout is needed for this problem.
I would try to move the VM on another computer.
I will appreciate any suggestion
This iusse can be fixed installing then last Virtal Machine version.
First I removed last Windows Update 20H2.
Then I installed Virtual Machine last version.
Then Xilinx Ise 14.7 Win 10 keeping the Installed Virual Machine.
Finallly I updated the Windows 20H2.
All now is fine and works very good.
ansarimo
Hi lucapodesta@libero.it
Good to know that you have managed to pass this issue, thanks for sharing this valuable information with us.
Please let us know if you need any further assistance in relation to this topic, or else close this thread by accepting it as a solution.
Thanks and Regards,
Ansari Hunen
Don’t forget to reply, kudo, and accept as a solution.
