Newbie 17trickc
ISE™ Design Suite 10.1
We're in a little trouble here. We have some older boards the need to be updated. The Xilink's are on longer supported with the newer versions. I need to find a link to download ISE™ Design Suite 10.1. Can anyone help.
Re: ISE™ Design Suite 10.1
Hi @17trickc,
Please check this link and download both 10.1 and 10.1 SP3:
https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/design-tools/archive.html
Raj
Teacher drjohnsmith
note : what OS you want to run on ?  These won't work on windows 10 , and may not windows 7..  check
Hello @17trickc,
Have you now managed to download and install 10.1 on your machine?
If so, and if your query is answered now, please mark a response as 'Accepted Solution' (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions), so that the topic can be completed then.
We appreciate your help.
Have a nice day.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
@17trickc
You can check this Answer Record for list of supported OS: https://www.xilinx.com/support/answers/18419.html
Or this Answer Record to make ISE 10.1 run on Windows 10 : https://www.xilinx.com/support/answers/62380.html
Nupur
