david.hoffman
Is it possible to install Vivado without relying on a GUI?
I need to install Vivado on Ubuntu hosts that don't have any graphics libraries installed. I've been trying to install using batch mode but the post installation steps include running XIC which causes the installation to fail (due to its dependency on java graphics libraries).
David
hbucher
@david.hoffman  The same happens when we run Vivado in the cloud or headless operation - you have to install a dummy driver.
We go over this on a few of our videos
http://www.vitorian.com/x1/archives/484 Launch Amazon AMI
http://www.vitorian.com/x1/archives/488 Install dummy driver
http://www.vitorian.com/x1/archives/497 Window manager
http://www.vitorian.com/x1/archives/510 Tunnel for reverse programming
hbucher
eliezer
Hey, it seems those links are dead
anatoli
Hello @eliezer ,
There is a Batch Mode installation flow provided in the (UG973) (v 2019.2). This has steps on how to install Vivado without relying on a GUI.
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
eliezer
That does help, thank you very much!
hbucher
Fixed. I maintain my own site at amazon so it's not without its hassles
