cpagravel
Is there a safe way to update the Xilinx IP blocks?
I'm working on large project with a lot of Xilinx IP blocks and I've noticed that if I try to update a piece, it will reset the settings that I have configured on the block. I.e. a Fifo will not have the same options or size that I originally set for it. Is there a safe way to update the Xilinx components so that I don't have to waste time? The possibility of over looking something that could cause a huge set back in debugging time is troublesome.
I'm using Xilinx Vivado. My current design is in 2015.3 (some parts are already in 2015.4) and I want to migrate to 2016.2.
Is there a safe way to do this? I would hope that Xilinx has this all figured out already.
Thanks for the time!
Tags (4)
syedz
@cpagravel,
Yes, if there are no warning messages in the upgrade log of the IP then you can be confident that the design will perform as it was intended before the upgrade.
Syed
balkris
its usually give the warning when changing the core configuration to default settings . In some IPs there are dependent setting . Means when you select certain settings will reset automatically . I would recommend to take a backup before design update.
Check the migration guide as well
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_1/ug911-vivado-migration.pdf
Thanks and Regards
Balkrishan
vemulad
Hi @cpagravel
Are you changing the FPGA device too?
You can check the IP upgrade log to see if the upgrade is successful or not. This file is located in project directory. Incase if there are some IP differences between old and new versions of Vivado and if the tool was not able to upgrade the IP properly there will be warning messages issued to alert the user.
Deepika.
cpagravel
The device is staying the same. I am worried about the update changing the settings I've put on the IP block, or changes in the IP that might change the behavior and cause issues.
Can I assume that I only need to pay attention to warnings given to me by Vivado? I.e. if there's no warning, I can be confident that the design will perform as it was intended before the upgrade.
syedz
@cpagravel,
Syed
syedz
@cpagravel,
If the suggestion provided was helpful then please close this thread by marking the post as "Accept as solution"
--Syed
