Is there an upgrade path between Vivado Design Edition and System Edition?
Hi all! My company is going to purchase a floating license for Vivado. Currently we only require the features present in the Design Edition of the software, but projects in the future may benefit from the High Level Synthesis of the System Edition. Is there a path for upgrading between these editions?
Re: Is there an upgrade path between Vivado Design Edition and System Edition?
Generally, you can get a trial license of HLS, but for permanent license, contact your FAE or some other distributor.
Refer to this link for details on distributors:
http://www.xilinx.com/about/contact/authorized-distributors.html
Nupur
Accept as solution if it resolved your query, give kudos if it led you to the solution.
Nupur
hi @cblam
You need to contact your FAE for this info.
Are you in contact with your FAE?
Nupur
Nupur
@pulim No I am not in contact.
I tried emailing a Sales Representative from New York last week, but haven't heard back yet. I am located in Massachusetts, United States.
hi @cblam
You can reach your FAE from the link pointed by Nupur.
