leytronix
License error
I am using XPS 14.7 and today it stopped working because of a license error. I am getting the following messages:
ERROR:Security:8 - A feature for XPS was found but is expired.
   WARNING:Security:9b - No 'XPS' feature version 2013.10 was available for part
   'xc6slx45'.
   ERROR:Security:12 - No 'xc6slx45' feature version 2013.10 was available (-5),
        so 'XPS_TDP' may not be used.
What to do to get this project running again?
Tjerk
pulim
Can you attach the license and xinfo file here?
leytronix
Herewith the requested files.
Tjerk
pulim
HI,
The license you are having is ISE webpack license.
With this license you can use XPS feature for xc6slx45 device.
XPS feature is available for only three smallest zynq devices with webpack license.
You should have Embedded Edition or System Edition license to use XPS with xc6slx45 device.
See below link to for the features available with ISE webpaack license.
http://www.xilinx.com/products/design-tools/ise-design-suite.html
leytronix
Ok thanks for your clear answer. What is the price of those editions? I can only find prices of Vivado on the website.
Tjerk
pratham
Hi @leytronix.
Vivado system edition includes the ISE system edition as well.
-Pratham
leytronix
Ok, but that is a lot of money for only a small project. My project always has worked with Webpack. I still do not understand why it has stopped working now.
I have also bought an EDK licence before.
Tjerk
syedz
HI,
"My project always has worked with Webpack. I still do not understand why it has stopped working now."
Was it for the same device which you are using now?
The below snapshot from ISE 14.7 IRN (UG631) shows the list of devices which are supported with ISE webpack tool.
--Syed
leytronix
Yes, my device XC6SLX45 is also on the webpack list so I am flabbergasted that I get the license error. It is complaining that the XPS feature is expired.
   'xc6slx45'.
   Feature has expired.
   Feature:       XPS
   Expire date:   24-feb-2015
ashishd
Hello @leytronix,
When I inspected xinfo.txt, it shows that XPS feature which you were using was with the trial version of license and which got expired on 24-feb-2015. Now the license which you are having as your active license (Xilinx.lic) is a WebPack one and it supports XPS feature only for three smallest zynq devices. You can chech this here. So XPS feature won't work with XC6SLX45 device using this license.
In order to get the price related information about Embedded Edition or System Edition license, you can contact nearest authorized distributors in your region. You can find below links helpful to locate the one.
http://www.xilinx.com/company/contact/auth-disti-table.htm
http://www.xilinx.com/company/contact/sales-offices.htm
Ashish
ashishd
Have you checked response to your query?
Are you still doubtful about the cause of the issue? Feel free to update the thread.
Ashish
leytronix
Yes, I have seen it. However, buying a 5k licence is way out of my league!
ashishd
Hello @leytronix,
Thanks for the updates. You can close the thread by marking helpful post as solution in the interest of other users.
Ashish
