Visitor thomasle
License feature v_tpg missing, although feature VPG is there...
Host-ID of license server is correct, this is a sequence of our license file, including PACKAGE TPG
SERVER production 005056A17F8E 2100
USE_SERVER
VENDOR xilinxd
# This is a permanent license generated on Mon Jan 28 09:03:39 UTC 2019
INCREMENT TPG xilinxd 2020.01 permanent 9999 57925F68A655 \
VENDOR_STRING=License_Type:Bought;dkissler,TPG,ip,permanent,_211585961_178859378_0_348 \
ISSUER="Xilinx Inc" NOTICE="The license for this core was \
generated for dkissler on 01/29/2019It is the responsibility \
of the Licensee of this core to adhere to all terms and \
conditions of the applicable license agreement when using this \
core." START=28-Jan-2019 TS_OK
# The following PACKAGE definition is a REQUIRED part of this license:
PACKAGE TPG xilinxd 2020.01 8A57E7C7F2D1 COMPONENTS="v_tc v_tpg" \
OPTIONS=SUITE
--> How to get feature v_tpg?
BR, Thomas
Re: License feature v_tpg missing, although feature VPG is there...
Hello @thomasle,
Can you please confirm that you've stopped and then restarted your floating license server after you'd added the missing PACKAGE lines into your overall floating license file? If not, please stop the server and then restart it again and then see what the following command will bring to you?
lmutil lmdiag v_tpg
Please send me your full updated license file, for examination. Thanks
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
@thomasle
Are you using lmgrd version 11.14.1 to serve the license?
If not, use the license management tools given at end of this page: https://www.xilinx.com/support/download.html
Nupur
Visitor thomasle
thanks @nupurs
we already have v11.14.1.0 running, but not sure about the 2nd message:
[ecadadm@erlh1hjx vendors]$ ls -al
lrwxrwxrwx 1 ecadadm ecadadm 18 2017-10-27 12:40 xilinxd -> xilinxd_v11.14.1.0
-rwxr-xr-x. 1 ecadadm ecadadm 1949008 2014-06-11 11:06 xilinxd_v11.11.0.0
-rwxr-xr-x 1 ecadadm ecadadm 1650840 2017-10-27 12:37 xilinxd_v11.14.1.0
[ecadadm@erlh1hjx vendors]$ ./xilinxd
14:13:18 (xilinxd) Unable to initialize access to trusted storage: 2
14:13:18 (xilinxd) FlexNet Licensing version v11.14.1.0 build 194335 x64_lsb
14:13:18 (xilinxd) Vendor daemons must be run by the license server manager (lmgrd)
Visitor thomasle
@nupurs
Can you confirm that our feature "TPG" is the correct one, as the feature "v_tpg" is missung, which is not included in our license file?
Thomas
Hello @thomasle,
Can you please open a command prompt and CD to the location such as e.g.: C:/Xilinx/Vivado/2018.3/bin/unwrapped/win64.o
Then, from here, please run this command: lmutil lmstat –a –c <port_number>@<server_name> (in your case the command would be as followed: lmutil lmstat –a –c 2100@production -i)
Then please see if lmgrd is UP and xilinxd is UP too and then, see what version of flexlm utilities the server is/was started with? Do you see v11.14 for both lmgrd and xilinxd?
Also, all of your other current FL licenses are run on the 1718@erlh1hjx.w... floating license server.
However, this TPG license is generated for the server called "production" and the listening port 2100.
Is this license ment to be ran on a totally different server or together with the rest of your Floating licenses? If together with the rest, then you won't be able to merge these together, as these are generated for different machines.
Can you confirm on this please. Thanks
Kind Regards,
Anatoli Curran,
Visitor thomasle
Server is up:
[root@erlh1hjx ~]# /etc/init.d/flexlm_lm_erlh1hjx status
lmutil - Copyright (c) 1989-2016 Flexera Software LLC. All Rights Reserved.
Flexible License Manager status on Fri 2/1/2019 13:44
License server status: 1718@erlh1hjx.ww005.siemens.net
License file(s) on erlh1hjx.ww005.siemens.net: /var/flexlm/data/license.dat_lm_erlh1hjx:
erlh1hjx.ww005.siemens.net: license server UP (MASTER) v11.14.1
Vendor daemon status (on erlh1hjx.ww005.siemens.net):
alterad: UP v11.13.1
snpslmd: UP v11.14.0
syncad: UP v6.1
xilinxd: UP v11.14.1
sigasi: UP v11.13.1
lattice: UP v11.13.1
dvtlmd: UP v11.14.0
But no TPG at Port 1718.
[root@erlh1hjx ~]# lmutil lmstat -a -c 1718@erlh1hjx | grep tpg
Why do you mention Port 2100?
[root@erlh1hjx ~]# lmutil lmstat -a -c 2100@erlh1hjx
lmutil - Copyright (c) 1989-2011 Flexera Software, Inc. All Rights Reserved.
Flexible License Manager status on Fri 2/1/2019 13:47
Error getting status: Cannot connect to license server system. (-15,570:115 "Operation now in progress")
Hello @thomasle,
The license file you have provide is this one:
USE_SERVER
VENDOR xilinxd
OPTIONS=SUITE
As you can see this license was generated for the listening port 2100 and for the server name 'production'
Therefore, that is the reason why i mentioned 2100 port in my previous post.
Have you actually added this above license into your overall floating license file that is currently running on 1718@erlh1hjx.ww005.siemens.net?
If not, please talk to your floating license admin to get this merged into your overall license file. License files are candidates for combining under the following conditions:
  • The number of SERVER lines in each file is the same.
  • The hostid field of each SERVER line in one file exactly matches the hostid field of each SERVER line in the other file.
Anyhow, right now this TPG license isn't any good to you, as with floating type of licenses, you must start the floating license server. Just putting this file into the folder and then pointing to it with an environment variable (like with any Xilinx Node-Locked licenses) isn't going to work here, as this license is a Floating license and not a Node-Locked.
If any further clarification is needed, please let me know.
Kind Regards,
Anatoli Curran,
Hello @thomasle,
This topic is still open and is waiting for you. Can you please confirm if you have managed to overcome this issue by now? Or are you still seeing issue and would like us to help you further on this matter? Can you confirm on this please?
However, if your question is answered and/or your issue is solved, please mark the response that resolved your issue, as Accepted Solution (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions). This way, the topic can be completed then.  We appreciate your help.
Kind Regards,
Anatoli Curran,
Visitor thomasle
Dear @anatoli,
thanks for your feedback.You are right, the servername "production" (whereever it came from) is nonsense. I didn't see that.
But everytime I generate a new license, there is still port 2100 in the file, instead of 1718. How to change this?
Thx, Thomas
Hello @thomasle,
Can you please confirm, does 005056A17F8E Host/Mac ID belongs to the 'erlh1hjx.ww005.siemens.net' server or some other machine altogether?
When dealing with a Floating licenses, the server name and port number are the values that the user can manually modify within the license file, without breaking the license syntax.
Therefore, you can easily edit this file and modify this license from
SERVER erlh1hjx.ww005.siemens.net 005056A17F8E 2100
to
SERVER erlh1hjx.ww005.siemens.net 005056A17F8E 1718
Can you please run the following command (again, by CD'ing  and then running it from this location C:/Xilinx/Vivado/2018.3/bin/unwrapped/win64.o) and report back the output you would receive:
lmutil lmdiag v_tpg
Also, please generate and share your Xinfo report generated on your own PC.
Xinfo.txt can be generated by running the "report_environment –file xinfo.txt" command in Vivado TCL console.
Kind Regards,
Anatoli Curran,
Visitor thomasle
@anatoli - we are working under Linux (CentOS6), but the result shall be the same:
I used this license now:
SERVER erlh1hjx 005056A17F8E 1718
USE_SERVER
VENDOR xilinxd
.... (many other features here)...
# This is a permanent license generated on Mon Feb 11 13:24:36 UTC 2019
INCREMENT TPG xilinxd 2020.02 permanent 9999 A9178F8699A2 \
VENDOR_STRING=License_Type:Bought;thomasle,TPG,ip,permanent,_211187988_176453062_0_049 \
generated for thomasle on 02/12/2019It is the responsibility \
core." START=11-Feb-2019 TS_OK
PACKAGE TPG xilinxd 2020.02 DEC7E73FEEC1 COMPONENTS="v_tc v_tpg" \
OPTIONS=SUITE
# ----- REMOVE LINES BELOW HERE --------------------------
ecadadm@erlh2chx [305]> lmutil lmdiag v_tpg
FLEXnet diagnostics on Tue 2/12/2019 16:10
License file: 1718@erlh1hjx.ww005.siemens.net
No licenses for v_tpg in this license file
So still no success... can send complete license file .. any hints welcome
P.s. other features can be checked out:
erlh1slx [4]> lmutil lmdiag v_timebase
FLEXnet diagnostics on Tue 2/12/2019 16:24
"v_timebase" v2013.05, vendor: xilinxd
License server: erlh1hjx.ww005.siemens.net
floating license no expiration date
TS_OK: Checkout permitted when client is using terminal client
This license can be checked out
Hello Thomas,
Please send me your full license file for examination. I've PM'ed you my direct contact email address that you can use to share your full license file. I will review the license file and will get back to you then.
Please also share your debug.log file of your Floating license server. If you are a FL license admin, you'd know where to find this file. Thanks
Kind Regards,
Anatoli Curran,
Hello @thomasle,
Thanks for sharing your license file.
I can't locate the below mandatory PACKAGE TPG lines in your overall license file.
I can find the INCREMENT TPG lines, however its corresponding PACKAGE TPG lines, which contains the necessary (missing) feature are not copied into the overall lic file. Please make sure you add the below PACKAGE missing lines, then restart the server and you should be good to go then.
OPTIONS=SUITE
That is the reason for why Vivado can't find these "v_tc v_tpg" licensing features, as PACKAGE definition is missed to be copied into your overall license file. Please note that the PACKAGE definition is a REQUIRED part of the license.
Hope this helps.
Kind Regards,
Anatoli Curran,
Visitor thomasle
Hi Anatoli,
Increment TPG is included in line 973, could you please recheck?
The snip attached includes only this increment (but no v_tpg) when generating subsequent license:
Is there something else missing?
THx, Thomas
Visitor thomasle
P.s. not sure what you mean with "PACKAGE definition"  - is this missing? Where to get it?
Visitor thomasle
Hello Anatoli,
you were right, the PACKAGE string was not included, whyever I missed that.
Now it is included, this snip is part of the license file:
OPTIONS=SUITE
But still no feature v_tpg
[root@erlh1hjx ~]# lmutil lmstat -a -c 1718@erlh1hjx | grep v_
Users of v_scaler:  (Total of 69993 licenses issued;  Total of 0 licenses in use)
Users of v_scaler_v1_0:  (Total of 9999 licenses issued;  Total of 0 licenses in use)
Users of v_timebase:  (Total of 69993 licenses issued;  Total of 0 licenses in use)
Users of v_vdma:  (Total of 49995 licenses issued;  Total of 0 licenses in use)
Users of v_vdma_v1_0:  (Total of 9999 licenses issued;  Total of 0 licenses in use)
Users of v_osd:  (Total of 49995 licenses issued;  Total of 0 licenses in use)
Users of v_osd_v1_0:  (Total of 9999 licenses issued;  Total of 0 licenses in use)
Users of v_stats:  (Total of 59994 licenses issued;  Total of 0 licenses in use)
Users of v_enhance:  (Total of 49995 licenses issued;  Total of 0 licenses in use)
Users of v_ccm:  (Total of 49995 licenses issued;  Total of 0 licenses in use)
Users of v_ccm_v1:  (Total of 9999 licenses issued;  Total of 0 licenses in use)
Users of v_cfa:  (Total of 49995 licenses issued;  Total of 0 licenses in use)
Users of v_cfa_v1:  (Total of 9999 licenses issued;  Total of 0 licenses in use)
Users of v_gamma:  (Total of 49995 licenses issued;  Total of 0 licenses in use)
Users of v_gamma_v1:  (Total of 9999 licenses issued;  Total of 0 licenses in use)
Users of v_deinterlacer:  (Total of 49995 licenses issued;  Total of 0 licenses in use)
Users of v_tc:  (Total of 69993 licenses issued;  Total of 0 licenses in use)
Users of v_cresample:  (Total of 49995 licenses issued;  Total of 0 licenses in use)
Users of v_proc_ss:  (Total of 49995 licenses issued;  Total of 0 licenses in use)
Users of v_dp_txss1:  (Total of 9999 licenses issued;  Total of 0 licenses in use)
Users of v_dp_rxss1:  (Total of 9999 licenses issued;  Total of 0 licenses in use)
Users of v_rgb2ycrcb:  (Total of 9999 licenses issued;  Total of 0 licenses in use)
Users of v_rgb2ycrcb_v2:  (Total of 9999 licenses issued;  Total of 0 licenses in use)
Users of v_ycrcb2rgb:  (Total of 9999 licenses issued;  Total of 0 licenses in use)
Users of v_ycrcb2rgb_v2:  (Total of 9999 licenses issued;  Total of 0 licenses in use)
Any more ideas?
BR, Thomas
Hello @thomasle,
lmutil lmdiag v_tpg
Kind Regards,
Anatoli Curran,
Visitor thomasle
thanks very much @anatoli, with adding the correct PACKAGE lines it finally works.
erlh1slx [15]> lmutil lmdiag v_tpg
FLEXnet diagnostics on Wed 2/13/2019 13:06
"v_tpg" v2020.02, vendor: xilinxd
Many thanks for your support!
BR, Thomas
