Newbie eduardo10
License problem for Evaluation ISE
I have donwloaded ISE 13.4 and requested a evaluation license for it. I tried to run SysGen and keep getting the following:
- No 'SysGen' feature version 2012.01 was available for part 'xc6vlx240t'.
I have Matlab 2011b installed on my system. What can I do?
I thought the evaluation license doesn;t have any restriction.
Eduardo
Re: License problem for Evaluation ISE
The Xinfo file shows that the license for the software tools is not being detected.
Have a look at the similar issue thread and follow the suggestions mentioned in it.
http://forums.xilinx.com/t5/Installation-and-Licensing/ISE-14-2-licensing-issue/td-p/383711
Hope it helps,
Satish
 It looks like the generated license doesn't have license for the sysgen.
Can you please share the xinfo  and license files,so that we can check.
You can generate the xinfo by following the below steps:-
 Start--> All Programs -->Xilinx Design tools-->ISE Design Suite13.4--> Accessories --> Xinfo System Checker and after you run “Xinfo System Checker”, the Xinfo.txt report will be
generated and saved in your C (Home Drive):\Xilinx\13.4\ISE_DS\common folder, as a text file (.txt).
Satish
Newbie eduardo10
Attached is the xinfo file.
Hope it helps,
Satish
Newbie eduardo10
Thanks. I never got any license file. I received emails from Xilinx without problems but I never got the license file. I went to the license link and try to get it again and I got the following message:
Your new license file has been successfully generated and e-mailed to *****
But, I never got an email with that. I checked the junk mail and it is not there. I thought the license would be managed via ethernet.
Newbie eduardo10
I had to use a different email account and I got the license file. Everything seems to be working now. Thanks
If you do not receive your license by email, you can download it directly from the Xilinx Licensing Site.
Click the download button in the lower left in Manage Licenses page.
