akhilchandra
Licensing Problem : ./xlicclientmgr -l "format=xml"
akhil@akhil-Aspire-E1-571:~/viv/Vivado/2015.2/bin/unwrapped/lnx64.o$ ls
dccli                pcap_proxy_server         updatemem    xlicclientmgr
dsphash              saferun                   vcse_server  xlicsrvrmgr
FNPLicensingService  sg_config                 vivado       xsc
HAOPResynthWorker    svf_utility               vrs          xsim
hw_server            sysgensockgui             wbtcv        xvhdl
hw_serverpv          tclsh8.5                  xelab        xvlog
install_fnp.sh       test_rdi_burst            xilcurl
lmgrd                test_rdi_hwcosim_api      xilinxd
lmutil               unittest_sysgen_anytable  xilproxy
akhil@akhil-Aspire-E1-571:~/viv/Vivado/2015.2/bin/unwrapped/lnx64.o$ ./xlicclientmgr -l "format=xml"
ERROR: flxActCommonInit result 2   .
Exit(2) FLEXnet initialisation error.
akhil@akhil-Aspire-E1-571:~/viv/Vivado/2015.2/bin/unwrapped/lnx64.o$ xlicclientmgr -v
xlicclientmgr: command not found
anusheel
@akhilchandra
Check below AR:
http://www.xilinx.com/support/answers/60542.html
Anusheel
Search for documents/answer records related to your device and tool before posting query on forums.
Search related forums and make sure your query is not repeated.
Please mark the post as an answer "Accept as solution" in case it helps to resolve your query.
Helpful answer -> Give Kudos
akhilchandra
Thank you anusheel,
If my "libXLicSrvrMgrFNP.so" is in /home/viv/Vivado/2015.2/lib/lnx64.o
then to set the path I use
export PATH=$PATH://Home/viv/Vivado/2015.2/lib/lnx64.o
I am facing a problem even If I set the path
root@akhil-Aspire-E1-571:~/viv/Vivado/2015.2/bin/unwrapped/lnx64.o# export PATH=$PATH://Home/viv/Vivado/2015.2/lib/lnx64.o
root@akhil-Aspire-E1-571:~/viv/Vivado/2015.2/bin/unwrapped/lnx64.o# install_fnp.sh
install_fnp.sh: command not found
root@akhil-Aspire-E1-571:~/viv/Vivado/2015.2/bin/unwrapped/lnx64.o# ./xlicclientmgr –v
ERROR: –v is not a command or option.
Exit(1) error in command line.
root@akhil-Aspire-E1-571:~/viv/Vivado/2015.2/bin/unwrapped/lnx64.o# ./xlicclientmgr -l "format=xml"
ashishd
Hello @akhilchandra,
Are you using supported Linux version? Check page #9 from below UG
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_2/ug973-vivado-release-notes-install-license.pdf
Ashish
