kempkeng
Locked IP Core After Buying Node-Locked License
I recently purchased a node-locked Vivado license, upgrading from a prior evaluation license.  After installing the new license, I am unable to synthesize the projects which I was previously able (simulation works fine).  For example, I am unable to build the ten_gig_eth_pcs_pma IP core (10GBASE-R).  Vivado gives the following error message:
* IP 'ten_gig_eth_pcs_pma' requires one or more mandatory licenses but no valid licenses were found. However license checkpoints may prevent use of this IP in some tool flows.
10GBASE-R should be included with Vivado, so I am unsure why this error has cropped up.  I have also requested and installed the free license from here, but have had no additional success.  Any help or suggestions would be greatly appreciated!
kempkeng
This ended up being an incompatibility in versioning with the IP catalog.  I am unsure why the error message was cryptic, but updating the IP to the latest revision has fixed this issue.
Thank you @ashishd for the help.
ashishd
Hello @kempkeng,
Can you try resetting and regenerating output products for IP and check if you still observe the issue?
Ashish
kempkeng
Resetting gives a similar error message:
CRITICAL WARNING: [filemgmt 20-1366] Unable to reset target(s) for the following file is locked: <...>/xc7k410tffg900-2/ten_gig_eth_pcs_pma/ten_gig_eth_pcs_pma.xci
Locked reason:
Please select 'Report IP Status' from the 'Tools/Report' menu or run Tcl command 'report_ip_status' for more information.
ashishd
Hello @kempkeng,
Can you share the output of below command -
report_environment -file <directory_name>/xinfo.txt
Ashish
kempkeng
xinfo.txt is attached.
kempkeng
