DaWei_Wang
MPSoC ZU7EV Engineering Sample
I doubt whether the vivado design suit suport the ZU7EV FFVF1517-1E- ES. And which versions can I use ?
anatoli
Hi again @DaWei_Wang ,
ZU7EV FFVF1517-1E- ES9819 - this is neither es1 nor es2. This is a pre-production samples (as these do have ES9819 in the PN).
FYI -
XCZU7EV-1FBVB900IES9820 -- > ES2   (there was no ES1 for this device)
XCZU7EV-1FBVB900IES9819 -- > pre-production
XCZU7EV-1FBVB900I4569 -- > production
In this case you can select the production devices of the ZU7EV and not engineering samples (ES1/ES2). Pre-production and production is the same bitstream, so pre-prod and production can’t be selected differently in Vivado. In this case you'd need to use 2017.4 (or newer) because of the speedfile. In there you can then select XCZU7EV-1FBVB900I4569 and that would be the same for pre-prod and production devices.
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
anatoli
Hello @DaWei_Wang ,
ZU7EV ES2 support is available in 2017.2 and newer releases (up to the 2018.2.2 version of Vivado). You can use any one of these leases.
Please note that you'd also need a special ES2 license file in order to be able to enable this device in Vivado and to be able to successfully generate a bitfile targeting ZU7EV ES2 part in your design.
Hope this helps.
Kind Regards,
Anatoli Curran,
Versal Blogs
DaWei_Wang
What is ZU7EV FFVF1517-1E- ES9819 ? ZU7EV ES2 or ZU7EV ES1? If it is ZU7EV ES1,which version should I use?
anatoli
FYI -
Hope this helps.
Kind Regards,
Anatoli Curran,
Versal Blogs
DaWei_Wang
Thank you very much.
