dwisehart
Problem adding cable drivers to Vivado 2014.1
The first time I installed 2014.1, I did not select the cable drivers.  Now when I run the "Add Devices" installer, when I go to the page where the cable drivers are listed, the cable drivers are not checked, but checking them adds 0.0 Byte to be installed.
Clicking on Next says I need to select something:
How do I add the cable drivers?
Daniel
vuppala
Hi Daniel,
Try installing the cable drivers by selecting the option "Hardware Server (Standalone)" in the installer screen.
See below snapshot:
Vinay
vuppala
Hi Daniel,
See below snapshot:
Vinay
dwisehart
Thanks. That worked.
Daniel
anusharanga
Thanks for easy solution.
