Process "Map" failed
I bought ANVYL SPARTAN-6 board. I am using Xilinx ISE 14.7 with WebPACK free license installed (in the way told in the FAQ). But when I run it (ImplementTop Module), it said "Map:258 - A problem was encountered attempting to get the license for this architecture." I search the forum and someone said the license got expired but I just install the ISE today and even I use the trail license I should got 30 days. I've got the info attached.
Re: Process "Map" failed
Hi @konglee
I observe that you have Vivado WebPACK license and not ISE WebPACK license from Xinfo.txt
You need ISE WebPACK license or purchased license to overcome the issue.
Follow the steps mentioned in chapter 2 of the following user guide to generate an ISE WebPACK license: http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_1/iil.pdf
Vinay
sorry, I didn't attach the info.
Hi @konglee
Vinay
@vuppala wrote:
Hi @konglee
Vinay
Thanks for your reply. I was installed the Vivado for the first time but I then delete it in the xilinx website for license managment and then add the ISE WebPACK, it email me the license to show that it is for ISE WebPACK. But it still doesn't work
Oh, after I reload the license, and reboot my system, it works now.
Hi @konglee,
Glad to know that your issue is resolved. Please close this thread by marking "Accept as solution" to the answer that led you to solution in concern of other users.
Arpan
Arpan
