Re: Error Map 258
I have the same problem running the program file [ERROR:Map:258] No 'ISE' nor 'WebPack' feature version 2013.10 was available....
I have downloaded the license many times and the error still appears. I am using ISE 14.7. Can you help me please?
NEXYS 3- SPARTAN 6-XC6LX16-CS324
Re: Error Map 258
Can you attach license file and xinfo here to debug the issue?
To generate xinfo,
1. Start --> All Programs --> Xilinx Design Tools --> ISE Design Suite 14.x --> Accessories --> Xinfo System Checker (if using winodws)
2. source Xilinx Tools and run the command xinfo (if using linux)
Note: It is always good practice to create a separate thread when you have queries or issues.
Vinay
Re: Error Map 258
This issue is caused by an ISE software version newer than the version limit in the license file.In the example above, the ISE Design Suite13.2 has a version limit of 2011.06, but the license only allows software with a version limit of 2011.02 or earlier to run.
The version limit date indicates the month when the support contract expires. The support contract entitles a user to update the software with any version of that software released on, or before, the version limit month. If you attempt to run a version of the software released after the version limit, the license does not enable this version to run.
For more information on "expiration date" and "version limit date", please see: (Xilinx Answer 33770) and (Xilinx Answer 35022).
Thanks and Regards
Balkrishan
Re: Error Map 258
Also, can you post the complete log showing all messages here?
Nupur
Re: Error Map 258
Hi @erickrhf,
Can you please attach the xinfo and the license file as requested by @vuppala?
Check if the version limit is appropriate.
Rajesh
