Re: Unable to load activiation base license (float) : "unable to initialize access to trusted storge: 2"
We just purchased floating vivado-design license. I activate this actiavation based license by command "xlicsrvrmgr". After that, I still cannot see this activiation based license in the Vivado License Manager.
I checked the license server, and I notice the message "Unable to initialized access to trusted storage: 2". I think this is related to thi sissue.
Anyone has suggestion to solve this issue? Thanks,
Check this answer record: http://www.xilinx.com/support/answers/60650.html
Vinay
Please check the below posts
http://forums.xilinx.com/t5/Installation-and-Licensing/Unable-to-view-Activation-Base-License-in-VLM/m-p/488710#M7572
http://forums.xilinx.com/t5/Installation-and-Licensing/Unable-to-load-license-rights-into-trusted-storage/td-p/450834
Ashish
Vinay
I checked the record. And tried all the ways, but still get the same issue.
1, I checked my license file, it uses VENDOR instead of DAEMON.
2, I added the LD_Library path for xilinxd and also xilinxd_FNP.so, it doesn't work.
Any other suggestion? Thanks,
@vuppala wrote:
Vinay
@ashishd wrote:
I am using CENTOS for license machine, so it is not vm issue.
My issue seems to be similar to
I tried a little bit, and not working. Right now I am trying to contact "holtgrefe" to get more information.
Issue solved. It is stupid typo mistake when I do "LD_LIBRARY_PATH" in the first time.
Thanks again,
