sameer.al-obaidi
Re: technical support
hi ;
KC 705 evaluation kit include the system generator for matlab tool license or i buy it separately
vsrunga
Yes, Kintex-7 FPGA DSP Kit with High-Speed Analog has System edition so you can use the same license  for Sysgen as well
http://www.xilinx.com/products/boards-and-kits/AES-K7DSP-325T-G.htm
vsrunga
It looks kit will provide only Deisgn Edition so you may not be able to get sysgen with it
http://forums.xilinx.com/t5/Installation-and-Licensing/System-Generator-Error/td-p/331013
Please visit below link for more details
http://www.xilinx.com/products/design-tools/vivado.html
P.S- Always create separte threads for differnet issues.
sameer.al-obaidi
Hi;
i think included according to below :
the KC705 Evaluation kit includes Vivado System Edition http://www.xilinx.com/products/boards-and-kits/EK-K7-KC705-G.htm#cms-179607-2
and System Edition includes System Generator: http://www.xilinx.com/products/design-tools/vivado/integration/sysgen.html
pulim
As mentioned by Vanitha,The Kit includes Vivado Design Edition License and design edition will not include system generator.
From the same link you referred,
vsrunga
Even in the link you pointed under the name you can see that it is Design edition which do not include Sysgen.
Can you please recheck?
Vanitha
sameer.al-obaidi
Hi;
Thank you, so can use the design edition for matlab simulation because need it to built optical ofdm by using KC705.
sameer.al-obaidi
Hi;
or can i use the Kintex-7 FPGA DSP Kit with High-Speed Analog.
vsrunga
mahsamba92
Hi. I am trying to do a video transmission ( and processing later) using the nexys 3 FPGA with a student licence. After some research I found out that the best way to implement it is to use the Industrial Video Processing Kits (IVK). However, the #include for the IVK are not included in the hardware. The path is corectly set and the xparameters is included properly, but
 #include "ivk_video_resolution.h" is not included. How can I fix that, please?
