Running ISE 10.3 in Windows 7.
I want to install ISE 10.3 on my new computer, which is running Windows 7.  In the past I used the XP Emulator to run it, but Mictrosoft now discourages the use of that program.  It is still available.
Is there a way that I can run ISE 10.3 under Windows 7.
Pete D.
Re: Running ISE 10.3 in Windows 7.
Hi Pete D.,
It is not recommended to use ISE 10.3 on Windows 7.
As it is an unsupported OS with ISE 10.3
Check this answer record for supported OS: http://www.xilinx.com/support/answers/18419.html
Vinay
pdonegan@telinst.com Windows 7 is not officially suppored with ISE 10.3 but there are users who had successfully installed version on windows 7
Check this
https://www.youtube.com/watch?v=rdoL6k-_dF0
-Pratham
