Shashwat007
Running Vivado Webpack Windows just extracts and shows installer splash screen.
The Xilinx_Unified_2019.2_1106_2127_Win64.exe file runs and extracts. After the installation flash screen is shown and then it disappears. Nothing happens.
I tried following https://www.xilinx.com/support/answers/60118.html
I have set User Account Control(UAC) to never ask, disabled firewall.
The server in services is running as per https://forums.xilinx.com/t5/Installation-and-Licensing/Vivado-Webpack-2017-3-setup-fails-silently/td-p/809115
But I could not find xinstall file. Neither in %USERPROFILE%\AppData\Local\Temp or in C:\Users\<username>\.Xilinx\xinstall.
I manually extracted and ran the xsetup.exe but the result was the same (splash screen).
I did not understand resetting the path variable as told in https://www.xilinx.com/support/answers/60118.html
Shashwat007
I gave up on windows and installed it on linux. The webpack worked as intended.
anatoli
Hello @Shashwat007 ,
Can you confirm please, do you have MS Visual C++ 2015 both 64-bit and also 32-bit installed on this machine?
You'd need both x64 and also x86 (32-bit) version of MS VIsual C++ 2015 Redistributable as shown in my example screenshot below. In your case, do you only have x64, and x86 is perhaps missing?
Can you confirm on this please?
If needed, the Visual C++ redistributable 2015 (both 32 and 64 bit) can be downloaded from this link:
https://www.microsoft.com/en-us/download/details.aspx?id=48145
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
anatoli
Were you able to resolve this issue?
Is there any further assistance required in relation to this matter? If so, please let us know and we will be glad to help you further then.
However if your issue is resolved now, please mark a response as 'Accepted Solution' (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions), so that the topic can be completed then.
We appreciate your help.
Kind Regards,
Anatoli Curran,
Versal Blogs
Shashwat007
