jlaudolff
SDSoC: not checking out a license
SDSoc_Tools shows up in the license status. Why doesn't SDx see the license? When I open sdx, it asks me to acquire a license and opens the license manager.  Vivado is working just fine.
devinl
Community Manager
Community Manager
Hi @jlaudolff,
From the screen shot it looks like there is a version limit compatibility issue. The version limit of 2017.11 is only compatible with the tools up to version 2017.3 and I see this is the tools 2017.4 manager you have open.
Version Limit Chart - https://www.xilinx.com/support/answers/33770.html
Thank you,
Devin
devinl
Community Manager
Community Manager
Hi @jlaudolff,
Thank you,
Devin
anatoli
Hello @jlaudolff,
This topic is still open and is waiting for you.
If your question is answered and/or your issue is solved, please mark a response that resolved your issue, as Accepted Solution (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions), so that this topic can be completed then.
If this is not solved/answered, please reply in the thread.
Thanks in advance and have a great day.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
jlaudolff
Thanks for the reply. I have been out of the office but am back today.
The claim is a little confusing that 2017.11 has a version limit of 2017.3 because I have been using Vivado 2017.4 (without SDSoc) for quite awhile. I will retry SDSoC with Vivado 2017.3 today or on Monday.
Jim
jlaudolff
I don't see where SDSoC is available for 2017.3. Is this correct? Only 2017.2 or 2017.4?
Also, I see this on the 2017.4 installation page regarding FlexLM version.
jlaudolff
I was able to use the license with 2017.2.
jlaudolff
Thanks for your help. I missed the link you posted on first read. It all makes sense now.
@devinlwrote:
Hi @jlaudolff,
Thank you,
Devin
Thank you,
Devin
