Simulation engine failed to start: A valid license was not found for simulation
I'd like to run xsim by clicking "Run Simulation" in Vivado 2015.2 . However, in the Tcl console I see this error:
INFO: [Common 17-186] '/home/rob/xilinx-projects/bright_proj/bright_proj.sim/sim_1/behav/xsim.dir/ProgNetwork_behav/webtalk/usage_statistics_ext_xsim.xml' has been successfully sent to Xilinx on Mon Jul 13 16:01:02 2015. For additional details about this file, please refer to the WebTalk help file at /home/rob/sw/xilinx/xilinx-build/Vivado/2015.2/doc/webtalk_introduction.html.
INFO: [Common 17-206] Exiting Webtalk at Mon Jul 13 16:01:02 2015...
run_program: Time (s): cpu = 00:00:08 ; elapsed = 00:00:10 . Memory (MB): peak = 6669.582 ; gain = 0.000 ; free physical = 763 ; free virtual = 18006
INFO: [USF-XSim-4] XSim::Simulate design
INFO: [USF-XSim-61] Executing 'SIMULATE' step in '/home/rob/xilinx-projects/bright_proj/bright_proj.sim/sim_1/behav'
INFO: [USF-XSim-98] *** Running xsim
with args "ProgNetwork_behav -key {Behavioral:sim_1:Functional:ProgNetwork} -tclbatch {ProgNetwork.tcl} -log {simulate.log}"
INFO: [USF-XSim-8] Loading simulator feature
Vivado Simulator 2015.2
ERROR: [Simtcl 6-50] Simulation engine failed to start: A valid license was not found for simulation. Please run the Vivado License Manager for assistance in determining which features and devices are licensed for your system.
Please see the Tcl Console or the Messages for details.
However, if you look at the attached image, you'll see that my installed licenses include the license name "Simulation".
Why is Vivado complaining about "Simulation engine failed to start: A valid license was not found for simulation" ?
Thank you,
Rob
Hi Rob,
The reason for the license error is: Hostid mismatch. i.e., the hostid of the machine is different from the hostid in the license file.
I observe that the license file is generated with hostid: 52540019ee7e. You can cross check your hostid of the machine by running the command: lmutil lmhostid
You can rehost the license file using the steps mentioned in the section "Rehost or change the license server host for a license key file" in the following user guide: http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_5/irn.pdf
Vinay
