Suitable ISE for Spartan-6
I am using a SPEXI board with Spartan-6 on it and I am new to Xilinx board, I am trying to figure out which SDK or ISE is suitable to progeam and design on the board. Please enlighten me about the proper ISE to Spartan-6 I could not find a related topic regarding ISE supporting Spartan-6.
Re: Suitable ISE for Spartan-6
n,
14.7 is the version to use.
Austin Lesea
Principal Engineer
Xilinx San Jose
Professor
Professor
Is this the board you are talking about?  It looks like there's an XC6SLX150T on there.  That would require a full license for ISE rather than just the free webpack.  You would also need a full license to get the EDK if you wanted to use an embedded processor in your design.
-- Gabor
Yes, This is the board I am using. Is there any alternative because I am student and I cant afford a full license.
Hello @naani2901,
Check this Link:
http://www.xilinx.com/support/university.html
--Syed
Xilinx University Program (XUP) supports an expanded range of hardware development systems to complement the classroom learning experience with hands-on learning in the laboratory using Xilinx technology. These boards span the range from low-end, cost-effective solutions ideally suited to introductory classes, to the mid-range platforms suitable for teaching and senior projects, and the high-end that very effectively serve the graduate research community, but in addition are extremely suitable to all levels of undergraduate study.
You can verify in XUP boards link: http://www.xilinx.com/support/university/boards-portfolio/xup-boards.html. Those boards are mainly meant for university students.
n,
Ask your professor for how to get the license.  The XUP provides licenses to universities as part of the program.
Austin Lesea
Principal Engineer
Xilinx San Jose
@naani2901,
Did you get the Xilinx License with the above shared information on XUP?
Syed
