hermie
System Generator Error
I need help regarding the error message given below:
--------------------------------- Version Log ----------------------------------
Version Path
System Generator 14.3 C:/Xilinx/14.3/ISE_DS/ISE/sysgen
Matlab 8.0.0.783 (R2012b) C:/Program Files/MATLAB/R2012b
ISE C:/Xilinx/14.3/ISE_DS/ISE
Summary of Errors:
Error 0001: License failure - Required Hardware_Evaluation or Bought ...
Block: 'qam16_2/Subsystem/Subsystem2/Reed-Solomon Encoder 7.1 '
Error 0002: Internal Error
Error 0001:
Reported by:
Details:
License failure - Required Hardware_Evaluation or Bought license
for the block
Error occurred during "HDL Netlist Generation".
Error occurred during "Simulation Initialization".
Error 0001:
Reported by:
Details:
An internal error occurred in the Xilinx Blockset Library.
Please report this error to Xilinx (http://support.xilinx.com),
in as much detail as possible. You may also find immediate help
in the Answers Database and other online resources at http://support.xilinx.com.
I am trying to recreate a sample QAM Simulink model to be use for Kintex7 FPGA.
Thanks & Regards,
vemulad
Do you have evaluation/bought license of this core installed properly (open xilinx "Manage licenses" start--> ISE Desgin Suite --> Accesories --> Manage Xilinx Licenses)and check if you are able to see this core in the feature list of XLCM GUI)?
If yes, can you try using ISE/sysgen 14.4? There are few issues reported with 14.3 sysgen tool where it was unable to pick the few core licenses correctly. This has been fixed in 14.4.
Deepika.
Deepika.
hermie
There is no XLCM GUI on teh listed feature. The University bought Kintex7  7K325T Development kit with it is a voucher that entitle us to a Xilinx software design tool product.
vemulad
Check for the IP core name "rs_encoder/rs_decoder" in the feature list of Xilinx License manager.
If you donot find this feature and you do not have the license file for this core please generate an evalauation license from www.xilinx.com/getlicense. Refer to http://www.xilinx.com/support/answers/38883.htm for more details on how to generate free core license.
If possible please post your xinfo file.
In order to generate xinfo, please follow the steps below:
1.         Run Xinfo.exe from start menu start --> Xilinx ISE design suite --> Accessories --> xinfo system checker. It takes some time to generate Xinfo file.
2.         Check the common folder in Xilinx --> 14.X --> ISE_DS --> common folder for Xinfo file.
Deepika.
Deepika.
hermie
 Kindly find attached the info you requested.
vemulad
From the xinfo file it looks like you donot have license for reed solomon encoder.
Please generate evaluation license for reed solomon encoder. Refer to http://www.xilinx.com/support/answers/38883.htm for details on generating the license.
Once you generate the license, point the XILINXD_LICENSE_FILE to the location of the IP license in the "Xilinx License Configuration Manager" and click on set. You will find these steps in the email which will be sent to you once you create license file from www.xilinx.com/getlicense .
Deepika.
Deepika.
hermie
Are we not entitled for a node-locked license for this?
Whom can I ask regarding licensing?
Regards.
vemulad
The license which you get with KC705 kit (as per your post), is a vivado design suite license.
It will not include the license file for the reed solomon core. You can either generate the evaluation license as suggested earlier or contact your distributor/sales http://www.xilinx.com/company/contact/sales-reps.htm to purchase the license for this core.
deepika.
Deepika.
