Unable to load license rights into trusted storage
Accepted Solution Solved
Accepted Solution
i try  to activate Vivado Webpack 2014.1.
Vivado License Manager -> Load License -> Activate License ... -> Xilinx_License.xml
returns with "Unable to load License Rights into Trusted Storage"
Do you have any ideas?
Greets
Re: Unable to load license rights into trusted storage
To add to Vinay's suggestions...
Currently the Xilinx activation license generator is not able to support virtual machines. And will give the following error if an attempt is made to generate a license for a VM.
Error: API function 60009 failed, result 51412
There is a change request (CR#772376) associated with this issue and tentative plan is to fix this in Vivado 2014.3 release.
Until activation licensing is available for virtual machines, if the use of a virtual machine is required to serve a floating license, contact Xilinx Sales or Distributors to request that your license entitlement be changed from Activation to Certificate based licensing.
Thanks,Vijay
All Replies
Hi Greets,
Try these steps:
1. Open Command prompt
2. Navigate to <Vivado_installed_directory>\Xilinx\Vivado\2014.1\bin
3. run the command: xlicclientmgr -p <location_of_xml_file>\Xilinx_License.xml
Make sure to open command prompt using administrator privileges.
Try out these steps and still errors out, attach a snapshot of command prompt.
Vinay
su root
./xlicclientmgr -p Xilinx_License.xml
returns:
"ERROR: API function 60009 failed, result 51412
Response processing failed.
Exit(4) error when processing response."
Greets
Visitor ske
I have the same probles!
if i try this from :
return with:
what can i do!
Are you using VM?
Vinay
Visitor ske
yes.
Contact Xilinx Sales or Distributors related to this issue when using VM.
Vinay
Visitor ske
Thanks for your help.
Do you know if i can install Vivado on the same computer where i have installed Xilinx ISE?
That's why i have installed it on an vm.
Ralf
Hi Ralf,
You can install Xilinx ISE and Vivado in the same computer.
Vinay
Cant contact them, because an active case number is needed... Have got the same problem! Tried Windows XP, Ubuntu and Wondows 7
