se31berg
Uninstalling Vivado
Hello
I would like to uninstall Vivado Design Suite 2016.2. I think I am running Ubuntu 17
I've checked all of the threads available here and none of them seemed to work for me. When I navigate to /opt/Xilinx there is no .xinstall there. I don't know what to do. When I try to locate .xinstall using the terminal it says it's in /home/Xilinx/.xinstall/. When I try to navigate here I cannot find .xinstall within the directory.
prathikm
Hi @se31berg,
What happens when you run this in terminal ?
<install_path>\.xinstall\Vivado_2016.2\xsetup.exe –Uninstall
Prathik
Helpful answer -> Give Kudos
se31berg
In /home/Xilinx
It says command not found.
se31berg
prathikm
Hi @se31berg,
Try sudo ./xsetup -Uninstall
Prathik
tessitd
All,
The correct answer on a Linux System is:
cd <INSTALL_ROOT>/.xinstall/<VIVADO_VERSION>
Note that is a ".xinstall" directory with a "dot" in front if it.  It should be there if properly installed.
sudo ./xsetup -help
This will give you a list of available commands, it MIGHT be possible that the "execute" permissions bit is not on xsetup so you would need to change the permissions.
To complete an uninstall you would do:
sudo ./xsetup -b Uninstall
TomT...
markcurry
Linux tools (thankfully) don't involve Windows-like sillyness of registry files and other junk.  The following will "uninstall" Vivado:
rm -rf $INSTALL_ROOT/Vivado/$VERSION
If you installed SDK:
rm -rf $INSTALL_ROOT/SDK/$VERSION
Use sudo as appropriate.
Why complicate something simple?
Mark
Nmoellers
Removing the files will get rid of most of the data but some metadata in hidden files will be left behind. So if you ever want to reinstall Vivado, the proper scripts will need to be used (xsetup -b uninstall).
Nick
| Nick Moellers | FAE | Silexica, Inc. | n.moellers@silexica.com | https://www.silexica.com |
| Request a live demonstration of SLX FPGA High Level Synthesis tool here |
