Update Xilinx license with new host ID (MAC address)
Hi All,
We have a Xilinx ISE 14.7 toolchain license which is mapped to a particular host ID (MAC).
We need to update the license with a new MAC address and request to provide the shortest path to do the same.
Sharavanan A R
@sharavanan.ar
You can rehost the license by following this AR:
https://www.xilinx.com/support/answers/36136.html
--Syed
Hello @sharavanan.ar,
Were you able to rehost your license for your new PC? If not, and if you are still seeing issues, please let us know and we will be glad to help you further then.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
