VBoxManage.exe: error: Interface ('VirtualBox Host-Only Ethernet Adapter') is not a Host-Only Adapter interface (VERR_INTERNAL_ERROR)
Hi @nupurs,
I have installed ISE 14.7 on my windows 10 64 bit machine but I am getting following error. Please help.
Kritika Bhatia
Waiting for VM "ISE_14.7_VIRTUAL_APPLIANCE" to power on...
VBoxManage.exe: error: Details: code E_FAIL (0x80004005), component ConsoleWrap, interface IConsole
Is this the same post as
https://forums.xilinx.com/t5/Installation-and-Licensing/Installation-of-ISE-Design-Suite-14-1/m-p/907608#M24003
Yes,
Hello @toreachkritika,
Please check this AR: https://www.xilinx.com/support/answers/70239.html
This should give you some additional info on how to overcome this problem.
Looks like you may need to update to a newer version of VirtualBox in order for the tools to launch.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
