[VITIS] Installation on Ubuntu 18.04.05 fails due to Java Exception
When executing the .bin file downloaded from https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/vitis.html
an alert Image is shown saying that this Linux version is not directly supported but one can continue anyways. In the background one can already see that the installer is opened.
However in the terminal the following error message is shown:
Exception in thread "SPLASH_LOAD_MESSAGE" java.lang.IllegalStateException: no splash screen available
at java.desktop/java.awt.SplashScreen.checkVisible(Unknown Source)
at java.desktop/java.awt.SplashScreen.getBounds(Unknown Source)
at java.desktop/java.awt.SplashScreen.getSize(Unknown Source)
at com.xilinx.installer.gui.H.run(Unknown Source)
which makes the installation on the Ubuntu version impossible.
Any solutions to this?
Greetings,
Kevin
Hi @kevinkit ,
Please go through below forum discussion and check if it helps.
https://forums.xilinx.com/t5/Installation-and-Licensing/Installation-of-Vivado-2020-1-under-Centos-7-8-fails/td-p/1115482
Thanks and Regards,
Ansari Hunen
Don’t forget to reply, kudo, and accept as a solution.
Hi @kevinkit ,
Thanks and Regards,
Ansari Hunen
Thanks, it helped - however not supporting a minor version change is strange (18.04.04 is supported, 18.04.05 is not)
Greetings
Hi @kevinkit ,
Good to know that it helped you to solve the issue.
Please let us know if you need any further assistance in relation to this topic or else close this thread by accepting it as a solution so that it can help others.
Thanks and Regards,
Ansari Hunen
This should be closed when the bug is fixed not when a workarond makes it somehow work imho
