Vivadi not installing
I have downloaded Vivado https://www.xilinx.com/member/forms/download/xef.html?filename=Xilinx_Vivado_SDK_Web_2018.1_0405_1_Win64.exe&akdm=1 and tried to install on my computer which is 32bit operating system Windows 7 professional and 4GB RAM. I am getting following message:2tHIS INSTALLATION IS NOT SUPPORTED ON 32 BIT PLATFORM"
IS THERE ANY VERSION OF vIVADO FOR 32-BIT SYSTEM PLEASE?
Kind regards
@ashakil,
Problem is due to your 32bit OS and the installer being for 64bits.
The last supported ver. was Vivado 2014.4
I think any Vivado version before 2015.x was 32bits.
See this thread: https://forums.xilinx.com/t5/Installation-and-Licensing/Vivado-32bit-installation-In-windows7/td-p/732517
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
@ashakil,
Hi @ashakil,
Beginning from Vivado 2015.1, the support for 32 bit operating system has been removed.
