Vivado 2015.3 No Valid license found
licensing a Xilinx product seems to be very complicated.
I had a working Vivado installation (Linux) but I had to change the harddisk.
So I copied the /opt/Xilinx and the ~/.Xilinx directorys.
Vivado starts fine, but I can not run the sythesis. I alsways get:
[Common 17-345] A valid license was not found for feature 'Synthesis' and/or device 'xc7a100t'. Please run the Vivado License Manager for assistance in determining
which features and devices are licensed for your system.
Resolution: Check the status of your licenses in the Vivado License Manager. For debug help search Xilinx Support for "Licensing FAQ".
I reinstalled Vivado 2015.3 in a different directory but the same error. The vlm says that i have a Webpack license.
So where is the problem?
Can someone help me. Vivado is a nice tool and designing fpgas is really simple, but the licensing NOT.
Re: Vivado 2015.3 No Valid license found
hi @cuhrw
Re-installing the operating system is the root cause for the issue.
Can you rise a service request at below link selecting software and IP licensing,http://www.xilinx.com/support/service-portal.html
Customer service team would be able toa dd the license back to your account.
Then you can generate it again and use it with Vivado.
Hi @cuhrw
Source Xilinx Vivado tool and run the following command: xlicclientmgr -v "format=long"
Share the ouptut here.
Vinay
hi @cuhrw
Have you processed the license after downloading it?
You need to process the license then only it will be installed on your machine.
xlicclientmgr -p Xilinx_License.xml
Please run the below command and share the output.
report_environment -file xinfo.txt
Here are the outputs:
ERROR: API function 60009 failed, result 51307
No stored request for this response
Response processing failed.
The most likely reason is that this response has already been processed.
Exit(4) error when processing response.
report_environment can not be found
Viewing application trusted storage.
No fulfillment records in trusted storage.
hi @cuhrw
Looks like you ahve installed Vivado license.
Please type pwd in TCL console.
It will give you the current working directory.You can find xinfo in the current working directory.
Okay, sorry, I didn't know that I have to run the command in teh Tcl console.
The output is in the attachment.
HI,
I see only ISE webpack installed, with this you can't use Vivado.
Hi @cuhrw
Please follow below steps to generate and install Vivado webpack license.
  • Open Vivado License Manager
  • Select "Obtain License"
  • Select "Get Free Licenses - Vivado WebPACK, SDK, free IP and more"
  • Select "Connect Now".
  • After clicking "Connect Now", you should be taken to your account licensing page.
  • Login with your details and under activation based license section select Vivado webpack license and click on activate license.
Hello @cuhrw,
Can you share the output of below command and your license file here -
xlicclientmgr -l "format=xml"
Ashish
The license you have is ISE WebPACK. It can't be used for Vivado. You can get Vivado software from here.
http://www.xilinx.com/products/design-tools/vivado.html
You can contact a distributor if you need to purchase a license, or you must be having a WebPACK license of Vivado in your account. Refer to this link for distributors:
http://www.xilinx.com/about/contact/authorized-distributors.html
Nupur
Nupur
I do not really have the choice for vivado there (see attachement)
pic 2015-11-04 11:49:03.png
hi @cuhrw
The most likely reason might be you have already genertaed it.
Can you check in Manage license tab?
Do you have any license files with xml extension?
hi @cuhrw
You can generate and use Vivado 30 days evaluation license but this will be expired in 30 days.
You can use Vivado with all features for 30 days using this license.
Here is my vivado license file and a picture of the "view license status" tab.
What is about the Webpack License? I thought there is no time-limit on this?
It worked fine before the new installation.
Yes WebPACK does not have a time limit.
The new installation that you did, was it Vivado_WebPACK_Edition?
Nupur
Hi @cuhrw
Looks like the trusted storage been removed for this webpack license.
Have you re-installed operating system or done any modifications on your system after you have this license installed?
If you go to Load license -> activate license -> slect this xml file in the Vivado license manager do you see the same message indicating the license has been already processed?
When I do this I get "Unable to load License Rights into Trusted STorage. The most likely reason is that this response has already been processed".
Is there any way to uninstall Vivado completely from my computer, including every configuration an license management, so that I can reinstall it from the bare nothing?
Yes, I have reinstalled the Operating System.
hi @cuhrw
@cuhrw
As the trusted storage is removed, there is no way to return the license. You need to contact customer support team to get the license back to the account under create license tab.
Anusheel
Helpful answer -> Give Kudos
I contacted the support.
I also have the old harddisk. So I could boot the old system. Is there an option to deactivate (or something like this) the old license?
Thank you! This was the solution!
